OSError: No available NIC [Help]
CookieNinja
Post by CookieNinja » Tue May 17, 2022 1:14 pm
I'm having a trouble solving this error. So what I am using is a Raspberry Pico and a Wave pico-ESP8266 to supply it with wifi connection.
So it has no issue connecting to the internet and I also not having issues sending data to a TCP server. I'm trying to send data to my Firebase realtime database, but I keep running into this error and really dont know how to solve it. Code and error follows belowe.
main.py:
from machine import UART, Pin
from esp8266 import ESP8266
import time, sys, utime
from secret import AP_SSID, AP_Pwd, DataBase_URL, DataBase_Secret, Firebase_ProjectName, Web_API
import ufirebase as firebase
print("~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~")
print("RPi-Pico MicroPython Ver:", sys.version)
#Credentials
SSID=AP_SSID
Pass=AP_Pwd
DB_URL=DataBase_URL
DB_Secret=DataBase_Secret
## Create On-board Led object
led=Pin(25,Pin.OUT)
led_wifi=Pin(15,Pin.OUT)
led_communication=Pin(14,Pin.OUT)
## Create an ESP8266 Object
esp01 = ESP8266()
esp8266_at_ver = None
##Create WMC Object
Test communication to ESP8266
print("Communication: ",esp01.startUP())
while (esp01.startUP() == True):
    led_communication.toggle()
    break;
print("StartUP",esp01.startUP())
#print("ReStart",esp01.reStart())
print("Echo-Off",esp01.echoING())
print("\r\n\r\n")
Print ESP8266 AT comand version and SDK details
esp8266_at_ver = esp01.getVersion()
if(esp8266_at_ver != None):
    print(esp8266_at_ver)
set the current WiFi in SoftAP+STA
esp01.setCurrentWiFiMode()
#apList = esp01.getAvailableAPs()
#for items in apList:
#    print(items)
    #for item in tuple(items):
    #    print(item)
print("\r\n\r\n")
Connect with the WiFi
print("Try to connect with the WiFi..")
while (1):
    if "WIFI CONNECTED" in esp01.connectWiFi(SSID,Pass):
        print("ESP8266 connect with the WiFi..")
        led_wifi.toggle()
        break;
        print(".")
        time.sleep(2)
print("\r\n\r\n")
print("Now it's time to start Communication to Firebase\r\n")
firebase.setURL("https://homeproj-2cb1d-default-rtdb.firebaseio.com/")
firebase.put("/Sensor/Temp", "24", bg=False)
ufirebase.py
import ujson
import usocket
import ussl
import _thread
class FIREBASE_GLOBAL_VAR:
    GLOBAL_URL=None
    GLOBAL_URL_ADINFO=None
    SLIST={}
class INTERNAL:
  def connect(id):
      LOCAL_ADINFO=usocket.getaddrinfo(FIREBASE_GLOBAL_VAR.GLOBAL_URL_ADINFO["host"], FIREBASE_GLOBAL_VAR.GLOBAL_URL_ADINFO["port"], 0, usocket.SOCK_STREAM)[0]
      FIREBASE_GLOBAL_VAR.SLIST["S"+id] = usocket.socket(LOCAL_ADINFO[0], LOCAL_ADINFO[1], LOCAL_ADINFO[2])
      FIREBASE_GLOBAL_VAR.SLIST["S"+id].connect(LOCAL_ADINFO[-1])
      if FIREBASE_GLOBAL_VAR.GLOBAL_URL_ADINFO["proto"] == "https:":
            FIREBASE_GLOBAL_VAR.SLIST["SS"+id] = ussl.wrap_socket(FIREBASE_GLOBAL_VAR.SLIST["S"+id], server_hostname=FIREBASE_GLOBAL_VAR.GLOBAL_URL_ADINFO["host"])
          except:
            print("ENOMEM, try to restart. If you make to many id's (sokets) simultaneously (bg=1 and id=x), try to use less or use a board with more ram!\nSome emulation software limits the RAM.")
            FIREBASE_GLOBAL_VAR.SLIST["S"+id].close()
            FIREBASE_GLOBAL_VAR.SLIST["SS"+id]=None
            FIREBASE_GLOBAL_VAR.SLIST["S"+id]=None
            raise MemoryError
          FIREBASE_GLOBAL_VAR.SLIST["SS"+id]=FIREBASE_GLOBAL_VAR.SLIST["S"+id]
  def disconnect(id):
      FIREBASE_GLOBAL_VAR.SLIST["SS"+id].close()
  def put(PATH, DATA, id, cb):
        while FIREBASE_GLOBAL_VAR.SLIST["SS"+id]:
          time.sleep(2)
        FIREBASE_GLOBAL_VAR.SLIST["SS"+id]=True
      except:
      INTERNAL.connect(id)
      LOCAL_SS=FIREBASE_GLOBAL_VAR.SLIST["SS"+id]
      LOCAL_SS.write(b"PUT /"+PATH+b".json HTTP/1.0\r\n")
      LOCAL_SS.write(b"Host: "+FIREBASE_GLOBAL_VAR.GLOBAL_URL_ADINFO["host"]+b"\r\n")
      LOCAL_SS.write(b"Content-Length: "+str(len(DATA))+"\r\n\r\n")
      LOCAL_SS.write(DATA)
      LOCAL_DUMMY=LOCAL_SS.read()
      del LOCAL_DUMMY
      INTERNAL.disconnect(id)
      if cb:
          cb[0](*cb[1])
        except:
            cb[0](cb[1])
          except:
            raise OSError("Callback function could not be executed. Try the function without ufirebase.py callback.")
  def patch(PATH, DATATAG, id, cb):
          time.sleep(1)
      except:
      LOCAL_SS.write(b"PATCH /"+PATH+b".json HTTP/1.0\r\n")
      LOCAL_SS.write(b"Content-Length: "+str(len(DATATAG))+"\r\n\r\n")
      LOCAL_SS.write(DATATAG)
      del LOCAL_DUMMY
      if cb:
          cb[0](*cb[1])
        except:
            cb[0](cb[1])
          except:
  def get(PATH, DUMP, id, cb, limit):
          time.sleep(1)
      except:
      LOCAL_SS.write(b"GET /"+PATH+b".json?shallow="+ujson.dumps(limit)+b" HTTP/1.0\r\n")
      LOCAL_SS.write(b"Host: "+FIREBASE_GLOBAL_VAR.GLOBAL_URL_ADINFO["host"]+b"\r\n\r\n")
      LOCAL_OUTPUT=ujson.loads(LOCAL_SS.read().splitlines()[-1])
      globals()[DUMP]=LOCAL_OUTPUT
      if cb:
          cb[0](*cb[1])
        except:
            cb[0](cb[1])
          except:
  def getfile(PATH, FILE, bg, id, cb, limit):
          time.sleep(1)
      except:
      while not LOCAL_SS.readline()==b"\r\n":
        pass
      LOCAL_FILE=open(FILE, "wb")
      if bg:
          LOCAL_LINE=LOCAL_SS.read(1024)
          if LOCAL_LINE==b"":
            break
          LOCAL_FILE.write(LOCAL_LINE)
          time.sleep_ms(1)
          if LOCAL_LINE==b"":
            break
      LOCAL_FILE.close()
      del LOCAL_DUMMY
      if cb:
          cb[0](*cb[1])
        except:
            cb[0](cb[1])
          except:
  def delete(PATH, id, cb):
          time.sleep(1)
      except:
      LOCAL_SS.write(b"DELETE /"+PATH+b".json HTTP/1.0\r\n")
      del LOCAL_DUMMY
      if cb:
          cb[0](*cb[1])
        except:
            cb[0](cb[1])
          except:
  def addto(PATH, DATA, DUMP, id, cb):
          time.sleep(1)
      except:
      LOCAL_SS.write(b"POST /"+PATH+b".json HTTP/1.0\r\n")
      if DUMP:
        globals()[DUMP]=LOCAL_OUTPUT["name"]
      if cb:
          cb[0](*cb[1])
        except:
            cb[0](cb[1])
          except:
def setURL(url):
    FIREBASE_GLOBAL_VAR.GLOBAL_URL=url
        proto, dummy, host, path = url.split("/", 3)
    except ValueError:
        proto, dummy, host = url.split("/", 2)
        path = ""
    if proto == "http:":
        port = 80
    elif proto == "https:":
        import ussl
        port = 443
        raise ValueError("Unsupported protocol: " + proto)
    if ":" in host:
        host, port = host.split(":", 1)
        port = int(port)
    FIREBASE_GLOBAL_VAR.GLOBAL_URL_ADINFO={"proto": proto, "host": host, "port": port}
def put(PATH, DATA, bg=True, id=0, cb=None):
    if bg:
      _thread.start_new_thread(INTERNAL.put, [PATH, ujson.dumps(DATA), str(id), cb])
      INTERNAL.put(PATH, ujson.dumps(DATA), str(id), cb)
def patch(PATH, DATATAG, bg=True, id=0, cb=None):
    if bg:
      _thread.start_new_thread(INTERNAL.patch, [PATH, ujson.dumps(DATATAG), str(id), cb])
      INTERNAL.patch(PATH, ujson.dumps(DATATAG), str(id), cb)
def getfile(PATH, FILE, bg=False, id=0, cb=None, limit=False):
    if bg:
      _thread.start_new_thread(INTERNAL.getfile, [PATH, FILE, bg, str(id), cb, limit])
      INTERNAL.getfile(PATH, FI3LE, bg, str(id), cb, limit)
def get(PATH, DUMP, bg=False, cb=None, id=0, limit=False):
    if bg:
      _thread.start_new_thread(INTERNAL.get, [PATH, DUMP, str(id), cb, limit])
      INTERNAL.get(PATH, DUMP, str(id), cb, limit)
def delete(PATH, bg=True, id=0, cb=None):
    if bg:
      _thread.start_new_thread(INTERNAL.delete, [PATH, str(id), cb])
      INTERNAL.delete(PATH, str(id), cb)
def addto(PATH, DATA, DUMP=None, bg=True, id=0, cb=None):
    if bg:
      _thread.start_new_thread(INTERNAL.addto, [PATH, ujson.dumps(DATA), DUMP, str(id), cb])
      INTERNAL.addto(PATH, ujson.dumps(DATA), DUMP, str(id), cb)
Please help
scruss
Re: OSError: No available NIC [Help]
Post by scruss » Tue May 17, 2022 3:21 pm
I think you forgot the error messages.
I don't know this module, but does the esp8266 library open a normal network connection? It looks like firebase is looking for one and perhaps not finding it. Also, unless you are running a very new version, _thread on RP2040 is not very reliable.
