how import lwip?
ryota
how import lwip?
Post by ryota » Thu May 19, 2022 5:06 pm
hello
I would like to know how to use the lwip in this conversation. https://github.com/micropython/micropython/pull/1517
when I run this command `make MICROPY_PY_LWIP=1 MICROPY_PY_LWIP_SLIP=1`, I got this error.
GEN build-standard/genhdr/qstr.i.last
In file included from ../../lib/lwip/src/include/lwip/init.h:40,
                 from ../../extmod/modlwip.c:40:
../../lib/lwip/src/include/lwip/opt.h:51:10: fatal error: lwipopts.h: No such file or directory
   51 | #include "lwipopts.h"
compilation terminated.
In file included from ../../lib/lwip/src/include/lwip/apps/mdns_opts.h:41,
                 from ../../lib/lwip/src/include/lwip/apps/mdns.h:41,
                 from ../../lib/lwip/src/apps/mdns/mdns.c:58:
In file included from ../../lib/lwip/src/core/def.c:61:
In file included from ../../lib/lwip/src/core/dns.c:87:
how do I fix this?
Re: how import lwip?
Post by Roberthh » Thu May 19, 2022 8:21 pm
The PR seems to have the lwip include files in extmod/lwip-include. Make sure that this path is included in the set of include directory names.
There is a lien in Makefile which seems to do that (line 249).
Anyway: this PR is pretty old, from 2015. So most likely it will not work.
The actual MicroyPython version uses LWIP and supports it. Might be better to use that as the starting point to enable SLIP.
ryota
Post by ryota » Fri May 20, 2022 2:59 am
Thank you for your reply!
How do I do this ?
