exec on micropython does not recognize local variable
puppet13th
Post by puppet13th » Mon Jun 06, 2022 2:08 pm
example code:
a = 1
b = 2
c = 3
def plus_one(number):
    code = 'print(a,b,c,number)'
    exec(code)
plus_one(4)
on micropython:
MicroPython v1.18 on 2022-01-17; ESP32 module with ESP32
>>> %Run -c $EDITOR_CONTENT
  File "<stdin>", line 9, in <module>
  File "<stdin>", line 7, in plus_one
  File "<string>", line 1, in <module>
NameError: name 'number' isn't defined
on cpython:
Python 3.7.9 (bundled)
>>> %Run test_exec.py
1 2 3 4
it is a bug or exec on micropython works differently from cpython?
mattyt
Re: exec on micropython does not recognize local variable
Post by mattyt » Tue Jun 07, 2022 2:12 pm
In this case, it is different to CPython (to reduce memory use).
See this documented difference: Code running in eval() function doesn’t have access to local variables
puppet13th
Post by puppet13th » Wed Jun 08, 2022 3:55 am
Thank you very much,you point me to the right direction. :D
i was able to make it works using these code example:
a = 1
b = 2
c = 3
    global num
    num = number
    code = 'print(a,b,c,num)'
    exec(code)
plus_one(4)
code output:
1 2 3 4
