I'm new to the forum and pretty new to MicroPython and coding in general. Still I spent most of my working life in the electronics industry and have specific experience in the embedded systems space.
I'm working on an implementation of a GPS/Wifi Beacon based on an ESP32 board and have found some excellent resources to leverage. Most specifically I am working on understanding the micropyGPS work - but, all in all, the learning curve is fairly steep!
I've got a GPS chip (taken from one of my fixed wing aircraft) which I therefore know works and hooked it up to UART2 on my ESP32 board.
This is an example of what I see...
b'\x00 \xfe'
b'\x00\xc0'
b'\x00\x8eNR\xfd\xbf, ,,,\xec\xd7\xff\xbf\x13\x90\x88:\xb9\xff\xff\xff\xff\xff\x92\x80\x1a\n'
b'4\xff\x02\x00,,,\xff\xff\xff\xff\xff\xff\xff\xbd\x0c\x04X*\xb7\xfd\x7f\xff\x96\x00%\x89\xa9\xff\xff\xff\xd7\xb5\x00\x00r,\xbd\x7f\xdb\x7f\x11\x00A,\xb1\xbd\xff\xff\xbd%\x0099,\xff\xff\xff\xd5\r\n'
b'HGP\xff\xff\xfd\xff\x96\x00\xbab\x92\xff\xff\x7f\xd7\xff\xbf\x02`7,\xae\xffkD\x00b\x92b'
b'\xff\xff\xff\xb5)\x00GLG\xf7\xff\xff$\x00\xea1\xfd\xff\xd7\xfd\xfb\xfd\xff\x0c\x04\xc5r\xad\xff'
b'\x00\x00\xfe'
b'\x00\xe0'
...when running this code:
# Setup the connection to your GPS here
# This example uses UART 3 with RX on pin Y10
# Baudrate is 9600bps, with the standard 8 bits, 1 stop bit, no parity
uart = UART(2, baudrate = 9600, tx =17, rx = 16, bits = 8, parity = None, stop = 1)
# Basic UART --> terminal printer, use to test your GPS module
if uart.any():
buf = uart.readline()
# buf = buf.decode("utf-8")
print(buf)
Clearly what I'd like to be able to confirm is that this is a valid NMEA sentence from the GPS chip but for the life of me I can't figure out how to convert this string of bytes into ascii which I might recognise. Unicode errors and sytax errors seem to be my speciality
I am sure I'm missing something here and would greatly appreciate some points to get me moving again.
All the Best
Harry
Decoding Bytes from a UART
Re: Decoding Bytes from a UART
Either the baud rate or the polarity is wrong.
Just to close the loop the problem came down to the simple mistake of failing to implement a common ground between the GPS sensor supply and the ESP32 supply. My data inputs were basically floating around. One simple wire link and the data became readable as ASCII characters. A stupid mistake on my part.
Cheers and thanks for the response.
Harry
Harry
Thanks for the follow-up... wish I'd thought of that to suggestflyboyCW12 wrote: ↑Sun Jul 10, 2022 9:38 amcommon ground between the GPS sensor supply and the ESP32 supply. My data inputs were basically floating around.
