add payload to POST request
Posted: Wed Jun 29, 2022 9:00 am
by Miliks
Hi guys,
i have a server with POST e REST services. Using micropython i need to perform POST request.
GET is performed and respond correctly using the following format:
s.send(b"GET /sensordata/premises HTTP/1.1\r\nHost:XX.XXX.XXX.XXX\r\n" + "Accept: application/json\r\n\r\n")
but for the POST looks like the request arrived at server, but the payload body is empty. For some reason, the JSON body of the request is not interpreted in the correct way.
from network import WLAN
import socket
import struct
import json
import pycom
wlan = WLAN(mode=WLAN.STA)
wlan.connect("*****", auth=(WLAN.WPA2, "*****"), timeout=5000)
while not wlan.isconnected():
    machine.idle()
print("Connected to WiFi\n")
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
url = 'XX.XXX.XXX.XXX'
sockaddr = socket.getaddrinfo(url, 80) [0][-1]
s.connect(sockaddr)
print('socket connected')
httpreq = b'POST /sensordata/insertrecords HTTP/1.1 \r\n Host:XX.XXX.XXX.XXX \r\n' + 'Accept: application/json \r\n' + 'Content-Type: application/json\r\n\r\n' + ' {\"node_id\":\"1\",\"value\":[{\"measure_time_stamp\":\"2020-10-06T09:25:43\",\"temp\":\"14\",\"humidity\":\"75\",\"ph1\":11,\"ph2\":12,\"ph3\":13}]}'
s.send(httpreq)
time.sleep(1)
rec_bytes = s.recv(4096)
print("RESPONSE = " + str(rec_bytes))
print('end')
s.close()
Re: add payload to POST request
Posted: Wed Jun 29, 2022 12:03 pm
by ChrisO
I haven't done this before, but I'm guessing you need to add the Content-Length header is well.
Posted: Wed Jun 29, 2022 12:07 pm
by ChrisO
someone will come along with a full fledged example, I'm sure.
In the meantime, if you won't want to wait. I'd take a cpython example like the one discussed here:
https://stackoverflow.com/questions/286 ... parameters
besides Content-Length it seems like you have to byte encode the information as well.
Posted: Wed Jun 29, 2022 1:29 pm
by p_j
Have you considered using 'requests', it might be easier and less error prone?
import urequests as requests
mydata = {'temp': 10, }
x = requests.post(url, json=mydata)
if x.status_code == 200:
    print("Done")
Posted: Wed Jun 29, 2022 2:56 pm
by Miliks
thanks, this was really helpful, it was really a matter of encoding and content-length parameters. the code below works perfectly:
headers =  """\
Content-Type: {content_type}\r
Content-Length: {content_length}\r
Host: {host}\r
Connection: close\r
\r\n"""
body_bytes = json_data.encode('ascii')
header_bytes = headers.format(
    content_type="application/json",
    content_length=len(body_bytes),
    host=str(host) + ":" + str(port)
).encode('iso-8859-1')
payload = header_bytes + body_bytes
s.sendall(payload)
Posted: Wed Jun 29, 2022 11:40 pm
by jimmo
Unless you're really optimising for every last byte of RAM and flash, then using urequests would be simpler -- see https://github.com/micropython/micropyt ... equests.py (it might already be installed on your device, e.g. ESP32!)
