IRQ to Stop a Script?
twodoctors
Post by twodoctors » Sun Jul 03, 2022 11:03 pm
Hi all,
Another question from this newbie! Sorry!
I've nearly finished my turning gallery target programme now. I've managed to utilise a 2004 LCD screen and a rotary encoder to drive a menu system on the main.py script. This would open another py script to run a specific timings for the targets. At the natural end of the script, it will bounce back to the main.py script. All that is working fine.
What I'm trying to add now is a "emergency stop" switch on my timing scripts.
Here is the crucial parts of the scripts (removed the lcd.putstr stuff to reduce clutter):
# Stop Button
stop = Pin(15, Pin.IN, Pin.PULL_DOWN)
# Normal Cycle
def Run():
    #Cycle (0 to ntimes)
    for x in range (0,1):
    # 5 seconds Edge Delay
        utime.sleep(5)
    # Face
        servoA.duty_u16(4500)
    # Face time (seconds)
        utime.sleep(8)
    # Edge
        servoA.duty_u16(1350)
# Normal End
def End():
    # End in Face after (delay)
    utime.sleep(3)
# Interrupt End
def Interrupt(Pin):
    lcd.clear()
    lcd.move_to(3,1)
    lcd.putstr("Stopped by User")
    quit()
# Interrupt Function
stop.irq(trigger=Pin.IRQ_RISING, handler=Interrupt)
lcd.clear()
# 1st Line
lcd.move_to(0, 0)
lcd.putstr("MT Match 4")
lcd.putstr("Go!")
utime.sleep(1)
#Run Script
Run()
End()
The IRQ is working to a degree. It is running the function ok, but what I want it to do is to end this script so it will stop completely and go back to main.py. For normal Python, there is the quit() function, sys.exit() and exit(). None of them works in MicroPython as far as I can work out.
Is there a better way of doing this?
Thanks!
Re: IRQ to Stop a Script?
Post by jimmo » Mon Jul 04, 2022 1:27 am
The closest equivalent we have is just to trigger a reset. Either soft (which clears all state starts the VM from the beginning and runs your main.py from scratch) or hard (which triggers a CPU reset). Sounds like soft reset is what you want.
machine.soft_reset()
FYI if you wanted to make this work with sys.exit instead...
when you call sys.exit, it raises SystemExit. So you can catch this in your main loop and then restart the program.
twodoctors
Post by twodoctors » Mon Jul 04, 2022 8:57 am
Thanks Jimmo.
I am currently using machine.rest as you suggested. I tried machine.soft_reset and it didn't stop the script for some reason.
# # Interrupt End
def Interrupt(Pin):
    lcd.clear()
    lcd.move_to(3,1)
    utime.sleep(2)
    machine.reset()
And that works out fine for the program for me.
Someone else suggested using global variable and False the while True statement to break the loop, but not able to work out how to do it yet. Have been trying that for the last hour or so!
(when you are a newbie, you just have to do it the convoluted way! :lol: )
Post by jimmo » Mon Jul 04, 2022 12:09 pm
stop = False
def interrupt_handler():
  global stop
  stop = True
def main():
  global stop
    stop = False
    while not stop:
      # do stuff
