Hi!
I need a PWM frequency of 400 on my ESP32 but it wont go lower then 611Hz.
I found this post https://github.com/micropython/micropython/pull/8200 discussing a solution.
Problem is: i also need ESPNow. Is there any build with ESPNow AND the frequency fix?
ESP32 PWM frequency bug
Re: ESP32 PWM frequency bug
Please update the firmware. This bug has been fixed a while ago.
Afaik the normal versions of mycropython still dont support ESPNow.
Luckily glenn posted ESPNow versions of micropython 1.19 just two days ago!
https://github.com/glenn20/micropython- ... g537248958
Good timing!
Good timing!
