@Strimis10,
Mind sharing how you got MicroPython on an ESP01? I am trying to do it, but after flashing, I can seem to connect to the REPL? Any help would be appreciated! Thanks.
Micropython WoL
Re: Micropython WoL
@Jibun no kageJibun no kage wrote: ↑Fri Aug 05, 2022 1:00 am@Strimis10,
ah yes, I also had a lot of trouble trying to get the firmware to work, first make sure your esp01 has 1mb of flash memory (if it has less it won't work) and then you need a specific firmware version (the one for 1mb boards). Here's the download: https://micropython.org/download/esp8266-1m/ I hope it works out for you!
Re: Micropython WoL
I can send and receive broadcasts without setting the sockopt. I get an Exception if I try to set SO_BROADCAST, which should be 0x20.
The code I used for testing on an ESP32 (4 MiB flash).
I also added a Contextmanager. I don't know if it's a guarantee in Micropython, that the __exit__ method is called, if an Exception occurs in the with-block.
from ubinascii import unhexlify
from socket import AF_INET, SOCK_DGRAM, socket
from micropython import const
BROADCAST_IP = const(b"255.255.255.255")
DEFAULT_PORT = const(9)
HEADER = "F" * 12
def create_magic_packet(macaddress: str) -> bytes:
for to_replace in ":- ":
macaddress = macaddress.replace(to_replace, "")
if len(macaddress) != 12:
raise ValueError("Incorrect MAC address format")
return unhexlify(HEADER + macaddress * 16)
class Closing:
Contextmanager to call close method before leaving context
def __init__(self, obj):
self.obj = obj
def __enter__(self):
return self.obj
def __exit__(self, exc_type, exc_obj, exc_tb):
self.obj.close()
def send_magic_packet(
*macs: str,
ip_address: str = BROADCAST_IP,
port: int = DEFAULT_PORT,
interface: str = None
) -> None:
packets = [create_magic_packet(mac) for mac in macs]
with Closing(socket(AF_INET, SOCK_DGRAM)) as sock:
if interface is not None:
sock.bind((interface, 0))
for packet in packets:
sock.sendto(packet, (ip_address, port))
# test with wireshark and use your MAC
send_magic_packet("74 e5 f9 4e 73 70")
send_magic_packet("74:e5:f9:4e:73:70")
send_magic_packet("74-e5-f9-4e-73-70")
time.sleep_ms(500)
Re: Micropython WoL
What if you have more than one device with WOL enabled? If you use the broadcast, are you qualify a specific MAC address as well? I was working with Node Red and WOL, and at one point I send WOL packet to every WOL enabled device on my network, that was interesting. If you only have one, single device, enabled for WOL, ok. Otherwise, surprise.
Re: Micropython WoL
Nothing would happen because each NIC checks if his MAC-Address is in the broadcast. If not, no action.What if you have more than one device with WOL enabled?
https://en.wikipedia.org/wiki/Wake-on-LAN#Magic_packet
The Wake-on-LAN implementation is designed to be very simple and to be quickly processed by the circuitry present on the network interface card with minimal power requirement. Because Wake-on-LAN operates below the IP protocol layer, IP addresses and DNS names are meaningless and so the MAC address is required.
