Can`t run a programm
Posted: Mon Jul 11, 2022 11:06 am
by nesergen
Good day!
I`m trying to start the program using function
pyb.main(bootFileName)
in the boot.py . But I get an error:
13:50:57.924 -> Traceback (most recent call last):
13:50:57.924 ->   File "main_v16.mpy", line 1
13:50:57.924 -> SyntaxError: invalid syntax
It is strange because if I use
import bootFileName
the file starts normally.
What may be the reason of such behavior?
Re: Can`t run a programm
Posted: Mon Jul 11, 2022 11:48 am
by jimmo
This should be
pyb.main("bootFileName.py")
But there's more going on because you're also using .mpy files (i.e. via the cross compiler)? Can you provide more information?
Posted: Mon Jul 11, 2022 11:52 am
by jimmo
Ohh... wait... are you trying to use a cross-compiled main_v16.mpy as your main.py? I think pyb.main has to be a .py file. You can only load .mpy via import.
Posted: Mon Jul 11, 2022 2:45 pm
by nesergen
You are right. I`m trying to start .mpy file. It`s not clear in docs that pyb.main() can only starts .py files.
Posted: Mon Jul 11, 2022 2:50 pm
by jimmo
I have just fixed this in a pending docs PR i'm working on.
