I don't see the need to have a dedicated driver written in C. Here is working MicroPython code to drive these LEDs: http://forum.micropython.org/viewtopic.php?f=2&t=149fma wrote:Nobody with STM32 C programming skills to write a dedicated driver for these leds?
How fast can an output pin be toggled?
- Markus Gritsch
Re: How fast can an output pin be toggled?
Very nice work! But you only drive 1 led, what if using a 600 leds strip? You will use all ressources sending datas to the leds...Markus Gritsch wrote:I don't see the need to have a dedicated driver written in C. Here is working MicroPython code to drive these LEDs: http://forum.micropython.org/viewtopic.php?f=2&t=149fma wrote:Nobody with STM32 C programming skills to write a dedicated driver for these leds?
Frédéric
- Markus Gritsch
And how would driver code in C help you? You still would have to prepare the LED color data in some buffer using Python, which will become the time critical part. Sending the buffer with some dedicated C driver or handing it to the SPI send function is not that different.fma wrote:Very nice work! But you only drive 1 led, what if using a 600 leds strip? You will use all ressources sending datas to the leds...
There was a discussion about using DMA... Ok, maybe a DMA() object could be enough, working with the SPI() object. But I guess using pure C could optimize things.
Anyway, I'll give a try to your solution, as I was looking for a nice demo to present micropython to local AFPY members. This is a cool one
Frédéric
- Markus Gritsch
If your intention is to drive lots and lots of WS2812 LEDs and not just display some rainbow pattern, there are other, more suitable means, e.g. http://spritesmods.com/?art=imx233-ws2811 or https://www.pjrc.com/teensy/td_libs_OctoWS2811.html
Driving just some tens of them is easily possible using pure Python.
