serial data reading with pico
Re: serial data reading with pico
Reading and writing serial data is done by the machine.UART class. See the documentation at https://docs.micropython.org/en/latest/ ... serial-bus.
To tell, whether the set-up is correct, you can do a loopback test.
You should read back the message you have written.
- Connect the max3232 level converter at the TTL side to the Pico, e.g. GPIO0 for TX (Pico out) and GPIO1 for RX (Pico in). Do not forget to connect the max232 GND with the PICO GND pin.
- Connect RX and TX at the rs232 side, e.g. with a jumper cable,
- Run in REPL:
from machine import UART, Pin
uart = UART(0, tx=Pin(0), rx=Pin(1))
uart.write("test message")
print(uart.read())
Try to swap the RX/TX at the PICO. The Pico TX must be connected with the Data in Pin of the max3232 TTL side, and PICO RX with max3232 out.
Is the max3232 converter powered?
Just to confirm: for the loopback test, you have to connect at the rs232 side rx and tx and no other connection to rx and tx at the rs232 side. RS232 GND does not matter.
The default baud rate for UART is 115200. If that is too high, you can set the baud rate as the second parameter, e.g.:
uart=UART(0, 9600, tx=Pin(0), rx=Pin(1))
Yes. It is hard to tell from a distance what could be wrong.
