Convert Byte-String to Ascii-String -SOLVED
MMliam
Post by MMliam » Mon Jul 25, 2022 2:59 pm
Steps that convert a byte-string to an ascii-string:
>>> print(Message)
b'4f6e'
>>> x=Message.decode('ascii')
>>> print(x)
4f6e
>>> y=ubinascii.unhexlify(x)
>>> print(y)
b'On'
>>> z=y.decode('ascii')
>>> print(z)
On
Is there a simpler, one step process to make the same conversion?
In other words turning this: b'4f6e' into this: On
MMliam
Re: Convert Byte-String to Ascii-String - SOLVED
Post by MMliam » Mon Jul 25, 2022 5:39 pm
Found the solution, to my own question :D
message=b'4f6e'
message=ubinascii.unhexlify(message).decode('ascii')
print(message)
On
Jibun no kage
Re: Convert Byte-String to Ascii-String -SOLVED
Post by Jibun no kage » Mon Jul 25, 2022 10:12 pm
I found this works... str(theByteString, 'utf-8') as well. Does the job of converting b'' string decoding. Maybe a good thing to avoid another import unless you really need it?
MMliam
Post by MMliam » Tue Jul 26, 2022 12:34 pm
I tried it in PYTHON Idle & micropython.
msg = b'4f6e'
msg = str(msg, 'utf-8')
print(msg)
4f6e
It did not decode the byte stream to - On
Tried:
msg = b'4f6e'
msg = str(msg, 'utf-8').decode('ascii')
File "<pyshell#4>", line 1, in <module>
AttributeError: 'str' object has no attribute 'decode'.
BTW: 'ascii' works as well as 'utf-8'
karfas
Post by karfas » Tue Jul 26, 2022 1:42 pm
In python 3 works
>>> msg = b'4f6e'
>>> result = str(binascii.unhexlify(msg), 'ascii')
>>> result
'On'
>>> type(result)
<class 'str'>
See documentation for unhexlify and str.
MMliam
Post by MMliam » Tue Jul 26, 2022 1:59 pm
The 'Jibun no kage' suggestion was to avoid importing "binascii"; your approach and mine require importing "binascii' for Python, or "ubinascii" for micropython.
scruss
Post by scruss » Tue Jul 26, 2022 2:22 pm
You'll always need (u)binascii for this kind of data, as it's a series of hexadecimal digits encoded as ASCII bytes. If it were bytes, the input would be b'On'
MMliam
Post by MMliam » Tue Jul 26, 2022 5:43 pm
I totally agree, binascii (Python), or ubinascii (microPython) is always necessary for these conversions.
Post by dhylands » Sat Jul 30, 2022 3:47 am
I also have a little utilty I wrote called dump_mem.py which you can find here:
https://github.com/dhylands/bioloid3/bl ... ump_mem.py
It prints out output that looks like this:
0000: 30 31 32 33 34 35 36 37 01234567
0008: 38 39 41 42 43 44 45 46 89ABCDEF
0010: 47                      G
It has options for specifying line length, adding a Prefix to each line, whether the ASCII should be shown along side the hex or not. whether the address should be shown, and what function to use to send the output to.
