problem with bytearray conversion
Re: problem with bytearray conversion
Post by dhylands » Mon Jan 04, 2016 6:56 pm
I've updated dump_mem.py so that it uses hexlify on micropython and regular hex formatting under cpython (since cpython's hexlify doesn't have the notion of seperators). https://github.com/dhylands/bioloid3/bl ... ump_mem.py It's a bit more code, but it uses memory much more effectively.
I also made log= be an argument rather than an imported module which makes dump_mem.py standalone.
After running dump_mem_test.py from the same directory, with the old version , the micropython heap looked like this:
stack: 416 out of 15360
GC: total: 102080, used: 17616, free: 84464
 No. of 1-blocks: 560, 2-blocks: 67, max blk sz: 80
GC memory layout; from 20003140:
03140: hthhhhhhhthBhMDhhhhhhhtttttttttttttttttttttttttttttttttttttttttt
03540: ttttttttttttttttttttttttttttttttttttthhhBhhBtthhthtttttttttttttt
03940: ttttttttttthhhhhhhttttttthttttt....hhhtLhthhhhhhhhhhhhhhhhhhhhht
03d40: hhthhhtttttttththtththhthhtthhtthhtthhtthhtthhhhhttttttthhthttth
04140: thhhhhhththhtttthtttthhhhhhhhhhhhhhthhthhhhhhhhtttttttttthhhthht
04540: hhtthhhhhhhhhhhhhhhhhhhhthhhhhhthhhhhhthhhhhhthhhhhhthhhhhhhtttt
04940: tttttttttttthtthhhhhtthhhhhhtthhhhhhtthhhhhhtthhhhhhttthhthhhhth
04d40: htttthhttttthhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhthhhhhhthhhhhhthhh
05140: hhhthhhhhhthhhhhhtthhhhhhtthhhhhhtthhhhhhtthhhhhhtthhhhhhttthhth
05540: hhhthhtttthhttttthhhhhhhhhhhhhhhhhhhhhhthhthhthhthhthhtthhtthhtt
05940: hhtthhtthhttthhhhthhtttthhtttthhhhhhhhhhhhhhhhhhhhhhhhhhhhthhthh
05d40: thhthhthhtthhtthhtthhtthhtthhttthhhhthhtttthhtttthhhhhhhhhhhhhhh
06140: hhhhhhhhhhhhhhhhhhhthhhhhhthhhhhhthhhhhhthhtthhttthhhhhhhhhhhhhh
06540: hhhhhhhhhhhhhhhhhhthhhhhhthhhhhhthhhhhhthhtthhttthhhhhhhhhhhhhhh
06940: hhhhhhhthhthhthhhhthhtthhtth........hhhhhhhhhhhhhhhhhhhhhhhhhhhh
06d40: hhhthhhhhhthhhhthhthhthhtthhtthhtthhtthhtthhttthhhhthhtttthhtttt
07140: hhhhhhhhhhhhhhhhhhhhhhhhhhthhthhthhthhthhtthhtthhtthhtthhtthhttt
07540: hhhhhhttthhttthhttttttttt.......................................
       (81 lines all free)
1bd40: ............................................
and with the new version it looks like:
GC: total: 102080, used: 10512, free: 91568
 No. of 1-blocks: 307, 2-blocks: 15, max blk sz: 80
03540: ttttttttttttttttttttttttttttttttttttthhhBBhhhhhhhhtttttttttttttt
03940: ttttttttttthhhhhhhttttttthttttthtttBtthhhh....hhhhhLhthhhhhhhttt
03d40: tthhhhhhtthhhhhhhttttttthhhhhttttthhhhhhhttttthhhttttttthhhhhhhh
04140: hhhhhhhththhtthhhhhhttttthhhhhhhhhhthhthhhhhhhhttttthhhhhhhhthht
04540: hhtthhhhhhhhhhtthhhthhhhhttttthhhhhhhhhhhtthhhhhhhhhhhhhhtttttth
04940: httttthhhhtttttttttthttttthhhhhhhhhhhhhhhhhhtthhhhhhhhhhttttthhh
04d40: htththtthhhhhttthhhhhhhhhhhhhhhthhhhhhhttthhhhhhhhthhhhhhhttthhh
05140: hhhhhhhhhhhhhhhhhhttth.........hhhttttthhhhhhhhhhhhhhhthhhthhhht
05540: tttttttttttttttttttttttttttthhhhhhhttttthhhhhtttthhhhhhhhhhhhhhh
05940: hhhtthhhhhhhhhhtttthhttttttttt..................................
       (88 lines all free)
which is about 7K less heap usage.
EasyRider
Post by EasyRider » Mon Jan 04, 2016 9:39 pm
Once again Thank you all.
print(binascii.hexlify(bytearray(message), b":"))
message being the integer list/array.
Does the trick nicely in converting and formatted printing of integer list/array > bytearray/hex string bytes.
PythonNoobie
Post by PythonNoobie » Wed Jan 22, 2020 7:49 pm
I realize this post is now over 3 years old, but something that helped me that I did not realize at first;
If I am not mistaken, pythons default output is in Unicode.
Unicode uses all the same characters that hexadecimal does, but also many more.
I kept thinking that my output was wrong because it looked like some bytes were okay and some were not.
What I didn't think about is: what is pythons defaults format is none is specified.
After adding .hex to ----> = ser.read(8).hex() compared to just writing ser.read(8). This fixed my problems.
Doesn't work on micropython for uart.read() though. This is a problem I am facing now!
You could try to store the initial reading into a variable and then convert later.
Always think about what format you may be in when not specifying one. Hope this helps someone.
