Strange ESP-Now Issue - SOLVED
davef
Re: Strange ESP-Now Issue
Post by davef » Thu Jul 28, 2022 10:16 pm
In a test system I was able to send multiple messages.
davef
Post by davef » Thu Jul 28, 2022 10:19 pm
The system cannot find the path specified. (os error 3) ??
MMliam
Post by MMliam » Thu Jul 28, 2022 10:26 pm
The error almost sounds like after the first send, ESP-Now lost it's object. I assumed the object would be static, if it's not after a send that's got to be an ESP-Now glitch.
MMliam
Post by MMliam » Thu Jul 28, 2022 10:35 pm
I printed out the ESP-Now object before and after the send; it appears unchanged. Still don't know what error 3 means.
davef
Post by davef » Thu Jul 28, 2022 10:38 pm
I will try to fire-up the test system again. Give me an hour or so.
davef
Post by davef » Thu Jul 28, 2022 10:44 pm
Need to correct a statement ... the working system is a ESPNow-only remote, but a ESPNow/WiFi local. I will try an ESPNow-only link.
MMliam
Post by MMliam » Thu Jul 28, 2022 10:48 pm
Dave,
I fixed the error, I had deactivated the ESP-Now object, because my code was intended as a one per boot. To test your issue I simply looped on my code every 10 secs.
Once I commented out the deactivation, the loop ran without issue; every 10 secs it sent a message - I let it run for 7 consecutive sends.
davef
Post by davef » Thu Jul 28, 2022 10:54 pm
Did you have a e0.active(False) at the "end" of your script?
MMliam
Post by MMliam » Thu Jul 28, 2022 10:58 pm
No, it was just after the send; there was a little extra bookkeeping after that. Frankly, because the code was intended as a send-per-boot, I really didn't need to deactivate.
davef
Post by davef » Thu Jul 28, 2022 11:05 pm
In most of my scripts I de-activate e0 before bailing-out. I have had grief in other areas with things being left in "unknown state".
If the issue is resolved, add [Solved] to the title.
