board.py Files
quiltyja
board.py Files
Post by quiltyja » Fri Jul 29, 2022 5:57 am
Edit: correct typo in subject and body, board.py is the file I'm enquiring about!
Hi everyone,
I connect with rshell to an ESP32 and rshell looks for via the function below which, because my code doesn't contain a file 'board.py' and thus always defaults to "pyboard". I can change that in a simple-minded kind of way by creating a 'board.py' file, but I'd prefer to adopt any standard or convention for 'board.py' if one exists. It turns out that ''board.py' and 'import board' make really poor search terms, so I'd like to ask if anyone knows where this file is found in the MicroPython ecosystem and whether there's a standard or convention for its contents?
def board_name(default):
    """Returns the boards name (if available)."""
        import board
            name = board.name
        except AttributeError:
            # There was a board.py file, but it didn't have an name attribute
            # We also ignore this as an error
            name = default
      return repr(name)
davef
Re: boot.py Files
Post by davef » Fri Jul 29, 2022 6:04 am
For the ESP32 I always have the boot.py that comes with the image. So, a blank boot.py should be enough. Also, I find it useful to have a file called main.py, which at least contains:
import my_application
A short delay in main.py, ie
utime.sleep(5)
gives you a chance to do a CTRL-C in rshell and edit stuff.
quiltyja
Re: board.py Files
Post by quiltyja » Fri Jul 29, 2022 6:11 am
Thanks, davef, for the quick reply! I'm sorry to say that I was interrupted while writing a question about board.py and when I returned to complete the post I'd just been working on boot.py... and thus made a typo in the subject and body :oops:. I've corrected that now and the subject and body both consistently refer to board.py.
Re: board.py Files
Post by dhylands » Sat Jul 30, 2022 3:24 am
The documentation for rshell is here: https://github.com/dhylands/rshell and the specific stuff about board.py is here: https://github.com/dhylands/rshell#file-system
quiltyja
Re: board.py Files
Post by quiltyja » Sat Jul 30, 2022 4:26 am
Thanks for the refs to the docs dhylands, I very much appreciate your writing rshell it's been very useful! What I'd like to know particularly is whether there's a convention, however loose, for the content of 'board.py' files?
For example, the Adafrult Blinka uses a board.py file, which makes me think that there's somewhat of a convention regarding 'board.py' files... ?
Re: board.py Files
Post by dhylands » Sat Jul 30, 2022 2:39 pm
I'm not aware of any convention per-say. When I create them they just look something like this:
name = 'custom'
I'm also not familiar with whats in Adafruit's board.py file.
