Hello Forum,
I am currently working on the Portenta H7 and I want to find a solution to update the micropython firmware running on the cortex M7 of the Portenta H7 .
Any guidance or insight/direction would be much appreciated.
Updating the MicroPython Firmware on Portenta H7
Re: Updating the MicroPython Firmware on Portenta H7
However you installed it in the first place, just do the same process again with a newer firmware image.Firas_Baccouri wrote: ↑Fri Jul 29, 2022 12:22 pmI am currently working on the Portenta H7 and I want to find a solution to update the micropython firmware running on the cortex M7 of the Portenta H7 .
You can download firmware and see flashing instructions here: https://micropython.org/download/ARDUINO_PORTENTA_H7/
If you're using OpenMV firmware then see https://docs.arduino.cc/tutorials/porte ... icropython
