Hi guys,
I am testing the server code by Peter from here on my ESP32 dev board: micropython-async/v3/as_drivers/client_server/userver.py
If I change the way I read from the stream on line 34 by calling sreader.read() rather than readline(), then there is around 3x to 4x performance boost. I am attempting to read a small HTTP header from a client, so readline() is quite useful in parsing the header as each header is separated line by line but if I read the whole thing in one go, it is way faster. If I have to use the read() function, then I have to manage the buffer myself in Python.
Does anyone have any ideas what could be the reason and what is the best way to approach this ?
Many thanks
Performance issue with streams and uasyncio on ESP32
Re: Performance issue with streams and uasyncio on ESP32
I assume the readline version in the code below (taken from https://github.com/peterhinch/micropyth ... userver.py) will happily read the last line and then wait for another one, until the timeout is reached.
The additional overhead caused by readline() and a task switch from the await is negligible, I think.
res = await asyncio.wait_for(sreader.readline(), self.timeout)
except asyncio.TimeoutError:
res = b''
if res == b'':
raise OSError
print('Received {} from client {}'.format(ujson.loads(res.rstrip()), self.cid))
swriter.write(res)
await swriter.drain() # Echo back
except OSError:
pass
A few hours of debugging might save you from minutes of reading the documentation!
That is what I expect behvaiour-wise but I still do not understand the large difference in performance. If I read the whole request in one go (if bytes are available) and process it myself line by line, it is much faster
What is the absolute difference in performance you observe ?
And where do you measure ?
For the echo reply readline() might be a few milliseconds slower.
For interpretation of the whole request you send (several lines) the last readline() will wait for the specified timeout (as described above).
