SSD1306 1.3" OLED (128x64)
abhi_R2000
Re: SSD1306 1.3" OLED (128x64)
Post by abhi_R2000 » Mon Aug 08, 2022 6:34 am
I think I'm having some issues in wiring. I mean, I gave the correct connections, but sometimes it will show scattered pixels and sometimes it shows correct pixels and images as per the requirement.
abhi_R2000
Post by abhi_R2000 » Mon Aug 08, 2022 6:35 am
scruss wrote:
Thu Aug 04, 2022 11:55 pm
scattered pixels can also mean the wrong driver. Are you sure you're using an SSD1306 and not an SH1106?
Hi @scruss. I'll check that.
abhi_R2000
Post by abhi_R2000 » Mon Aug 08, 2022 6:37 am
Roberthh wrote:
Thu Aug 04, 2022 1:26 pm
Pull-Up resistors are usually 5-10kOhm. But the the display works with I2c, then there may be pull-up resistors on the display already.
They are placed between the signal wire (SDA or SCL) and Vcc.
I'll check it @Roberthh.
abhi_R2000
Post by abhi_R2000 » Mon Aug 08, 2022 9:00 am
Hi @scruss. I'm using SSD1306.
