\xFF is missing from UART.read()
garudaone
Re: \xFF is missing from UART.read()
Post by garudaone » Wed Aug 10, 2022 3:28 pm
Roberthh wrote:
Wed Aug 10, 2022 1:20 pm
To explain that problem. This is the interrupt handler:
static void uart_rx_intr_handler(UART_Callback_Param_t param) {
    // handles rx interrupts
    ringbuf_t *ringbuf = uart_ringbuf + param.port - 1;
    int* to_dupterm = uart_attached_to_dupterm + param.port - 1;
    for (uint32_t i=0; i<param.length; i++) {
        if (param.buf[i] == mp_interrupt_char) {
            if (*to_dupterm)
                mp_keyboard_interrupt();
        else
            ringbuf_put(ringbuf, param.buf[i]);
mp_interrupt_char is a signed int. param.buf is declared at signed char*. So a 0xff in the buffer expands in a comparison with an int to -1. That might explain, why 0xff is missing when mp_interrupt_char is -1. Usually the receive buffer would be set to an unsigned data type. In that case 0xff is expanded to 255, and the compare with -1 fails.
But that is only the first part of the problem. The other part consist in the path of "if (*to_dupterm)...". If that is true, an keyboard interrupt is raised. If that is false, the character from the buffer is NOT put into the ring buffer, but simply discarded.
:lol: :lol: Thanks, you are right
Actually, at first \x03 are missing and by setting micropython.kbd_intr(-1) helps to get back \x03. but unknowingly, it makes me missed the \xff.
SO I am fixing one problem while creating another problem. By trying micropython.kbd_intr(-2), I missed \xFE. What is your suggestion? I have recompile the python build?
Post by Roberthh » Wed Aug 10, 2022 3:54 pm
Option 1: Fix the firmware.
Option 2: Avoid the bug. If you can control both sides, exchange the data coded, e.g. as Ascii-Hex, which contains neither 0x03 nor 0xff.
Option 1 is the better choice. You can for instance leave the SDK as is is and just change uart.c:
        if (*to_dupterm && param.buf[i] == mp_interrupt_char) {
garudaone
Post by garudaone » Wed Aug 10, 2022 3:57 pm
Thanks a lot for your effort to help. I will have to recompile this(Option 1) because sometimes I read data from Modbus sensor.
garudaone
Post by garudaone » Thu Aug 11, 2022 7:02 am
Ok, problem solved after I updated and recompile the build.
Thank you very much
Post by Roberthh » Thu Aug 11, 2022 7:07 am
That's very good. I also left a note at the repository issue you have created, to leave that issue open.. That is a reminder to fix the bug in the main line, and a help for other people stumbling over the same problem.
