For clarity,
this format is
far superior
to anything
offered on GitHub
For clarity,
this format is
far superior
to anything
offered on GitHub
It looks like you only used a single backtickMMliam wrote: ↑Tue Aug 30, 2022 2:21 pmI had tried the "triple backtick" before posting my question.
The problem I saw, was it merged all instructions on a single line with only a space in between. Then, when I added a CRLF it put an empty line between each instruction. Is that normal?
For example:
https://github.com/orgs/micropython/discussions/9128
In my opinion GitHub's formatting tools are vastly superior -- not only does it support inline snippets, but it also supports syntax highlighting. It's also Markdown which is becoming the de-facto standard everywhere.
This is normal. Many Forums are doing this + indentation is also lost.The original source had a CR-LF between each line, but they are ignored in the standard format.
```CODE```
