urequests
priis
urequests
Post by priis » Thu Oct 06, 2022 8:50 am
Here is a minimal program (I use an esp32) to get some data from an url:
import urequests as requests
ssid = "myWifi"
password = "myPassword"
blueled=Pin(2,Pin.OUT)
station = network.WLAN(network.STA_IF)
station.active(True)
station.connect(ssid, password)
i=0
while station.isconnected() == False:
utime.sleep_ms(10)
i=i+1
print(i)
blueled.value(not blueled.value())
pass
print("Connection successful")
res = requests.get(url = "http://worldtimeapi.org/api/timezone/Europe/Paris")
print(res.text)
for i in range(0,10):
utime.sleep_ms(50)
Sometimes the program works, sometime it says 'no module urequests', and sometimes it says 'OSError: -202. How can I make it always work.
I find it very strange that the urequests module sometimes is there and sometimes not!?
Re: urequests
Post by jimmo » Thu Oct 06, 2022 8:54 am
As before, please open new topics at GitHub Discussions
Note the double-precision firmware you installed is a very old version (1.12).
priis
Re: urequests
Post by priis » Thu Oct 06, 2022 10:27 am
Where can I find a more recent version with double precision?
scruss
Re: urequests
Post by scruss » Thu Oct 06, 2022 2:14 pm
I think you'd have to build it from source, which isn't particularly easy. Roberto hasn't touched these builds in a while.
Are you sure you need double precision? Remember, these are microcontrollers here. Everything is constrained.
To free up memory, call res.close() after you're done with a request. That firmware might support ntptime, which is an alternative way of getting time sync. Note that MicroPython isn't particularly aware of timezones.
Also, your code might mean something if you used code tags:
ssid = "myWifi"
blueled = Pin(2, Pin.OUT)
i = 0
    utime.sleep_ms(10)
    i = i+1
    print(i)
    pass
res = requests.get(url="http://worldtimeapi.org/api/timezone/Europe/Paris")
print(res.text)
for i in range(0, 10):
    utime.sleep_ms(50)
