Detailed code for the pyb.Servo library
sdlc
Post by sdlc » Wed Feb 17, 2016 10:42 am
Hi All !
I am working on a project using a pyboard and servos.
I would be very interested in having the detailed code for the pyb.Servo library.
I have spend much time searching it, but I haven't found it yet....
Where could I find it?
Thank you very much!
Simon
Re: Detailed code for the pyb.Servo library
Post by dhylands » Wed Feb 17, 2016 1:55 pm
It's written in C. You'll find the code in this file: https://github.com/micropython/micropyt ... al/servo.c
You can also control servos by using pwm like what's done here: https://github.com/dhylands/upy-example ... ic_test.py
sdlc
Post by sdlc » Fri Feb 19, 2016 10:53 pm
Hi dhylands!
Thank you for your answer.
Actually, I have already implemented three functions in order to control my eight servos:
The first one generates PWM (I have adapted the PWM generation presented in the Quick Ref of the pyboard), the second one converts angles (in degrees) into a pulse width percent, and the third one allows me to control my servos by giving an angle order, and not a pwpercent.
My problem is following:
When I call the latter function several times with a short delay between each call (1 sec), the servo doesn't rotate continuously but step by step. And if the order remains the same, it "jerks" each second.
I don't have this problem when I use the Servo(X).angle() function.
Do you have any idea?
Post by deshipu » Sat Feb 20, 2016 12:10 am
My guess is that you are resetting the timer, instead of only changing the duty cycle. But really hard to tell without seeing the code.
sdlc
Post by sdlc » Sat Feb 20, 2016 9:31 am
It was indeed the case.......Stupid mistake!
Thank you!!
