UART IRQ
danielm
UART IRQ
Post by danielm » Wed Mar 02, 2016 9:06 pm
I am trying to setup second UART with interrupt for Nextion HMI display from REPL. What am I doing wrong?
Platform is WiPy port on custom CC3200 board.
>>> uart                   # this object is created in boot.py for terminal duplication
UART(0, baudrate=115200, bits=8, parity=None, stop=1)
>>> uart2
NameError: name not defined
>>> uart2 = machine.UART(1, baudrate=9600, bits=8, parity=None, stop=1, pins=('GP3', 'GP4'))
>>> uart2
UART(1, baudrate=9600, bits=8, parity=None, stop=1)
>>> def irq_fun():
...     received = uart2.read()
...     print("Received: ",received)
>>> uart2IRQ = uart2.irq(trigger = UART.RX_ANY, priority = 1, handler = irq_fun, wake=machine.IDLE)
>>> Uncaught exception in callback handler
TypeError:
TypeError exception shows after touching the button on the display.
When I try to call irq_fun() directly from REPL it works - these bytes are sent from Nextion HMI display by touch of a button once:
>>> irq_fun()
Received:  b'e\x00\x05\x01\xff\xff\xff'
danielm
Re: UART IRQ
Post by danielm » Wed Mar 02, 2016 9:33 pm
It seems that interrupt function is called with UART class parameter, on which I can call function any() ( it does not work with read() ).
>>> def irq_fun(obj):
...     print("Type: ", type(obj))
...     print(obj.any())
>>> Type:  <class 'UART'>
105
112
119
126
133
140
danicampora
Re: UART IRQ
Post by danicampora » Thu Mar 03, 2016 6:30 am
Please use the .readinto() method instead, since .read() needs to allocate memory to return the array, and memory allocations are not possible within interrupt context.
Cheers,
Daniel
danielm
Re: UART IRQ
Post by danielm » Thu Mar 03, 2016 9:09 am
Daniel, thanks, this seems to work ;-)
donikuy
Re: UART IRQ
Post by donikuy » Tue Feb 20, 2018 9:15 am
How can I get this to work on a pyboard? I cannot find any way of using interrrupts on uart.
Re: UART IRQ
Post by pythoncoder » Tue Feb 20, 2018 12:15 pm
You can't. See my reply here on ways to access the UARTs.
