OSX device not listed
A search for OSX here in the forum only shows difficulty with USB cables and getting the pyboard to appear as a drive.
That works fine for me. However, the first thing in the tutorial is to use an OSX terminal and screen /dev/usb.modem*
My/dev does not show any USB devices that might be the pyboard, and dmesg shows failures to make connections (but the volume noname shows on the dedsktop and I can edit main.py)
Any ideas on getting a terminal going? (Mac Mini 10.5.8 and upgrade is not an option).
I can switch to a Debian box or Ubuntu laptop if I have to, but really want to work with BBEdit.
Re: OSX device not listed
Sorry if this sounds stupid, but have you tried rebooting? I've been playing with Micro Python on a 2007 MacBook Pro; I have found that the USB system can get hung up in such a way that only a reboot can fix. Usually this happens because I wasn't careful to unmount the drive or disconnect the terminal program before unplugging or putting the computer to sleep, sometimes it was because of a hard crash of the Micro Python firmware running on the board. Annoying, because I typically would go months between reboots, but this is the only thing I have found to work. Good luck!
-Bryan
-Bryan
No love. Restart the Mac. Reset the Pyboard. I can edit main.py in the volume that appears on the desktop and I can eject (unmount) it. But I can not get a REPL prompt. Plus nothing in /dev
Is there firmware called UAC1 or UAC2? There is a history of UAC2 failing on 10.5.8 and 10.6.4
Here are some outputs with potentially useful info.
dmesg gives:
0 0 AppleUSBCDCACMControl: start - Failed to find the CDC driver
AppleUSBCDCACMData: start: InterfaceMappings dictionary not found for this device. Assume CDC Device...
0 0 AppleUSBCDCACMData: start - Find CDC driver failed
System Profiler reports:
USB Bus:
Host Controller Location: Built In USB
Host Controller Driver: AppleUSBUHCI
PCI Device ID: 0x27c9
PCI Revision ID: 0x0002
PCI Vendor ID: 0x8086
Bus Number: 0x3d
Pyboard Virtual Comm Port in FS Mode:
Capacity: 240 KB
Removable Media: Yes
Detachable Drive: Yes
BSD Name: disk3
Product ID: 0x9800
Vendor ID: 0xf055
Version: 2.00
Serial Number: 000000000011
Speed: Up to 12 Mb/sec
Manufacturer: Micro Python
Location ID: 0x3d100000
Current Available (mA): 500
Current Required (mA): 500
Mac OS 9 Drivers: No
Partition Map Type: MBR (Master Boot Record)
S.M.A.R.T. status: Not Supported
Volumes:
NO NAME:
Capacity: 112 KB
Available: 70 KB
Writable: Yes
File System: MS-DOS FAT12
BSD Name: disk3s1
Mount Point: /Volumes/NO NAME
And command line: system_profiler SPUSBDataType
USB Bus:
Bus Number: 0x3d
Capacity: 240 KB
BSD Name: disk3
Product ID: 0x9800
Vendor ID: 0xf055
Version: 2.00
Volumes:
NO NAME:
Capacity: 112 KB
Available: 70 KB
Writable: Yes
BSD Name: disk3s1
Volumes:
disk3s1:
Capacity: 112 KB
Available: 70 KB
Writable: Yes
dmesg gives:
USB Bus:
Bus Number: 0x3d
Capacity: 240 KB
BSD Name: disk3
Product ID: 0x9800
Vendor ID: 0xf055
Version: 2.00
Volumes:
NO NAME:
Capacity: 112 KB
Available: 70 KB
Writable: Yes
BSD Name: disk3s1
USB Bus:
Bus Number: 0x3d
Capacity: 240 KB
BSD Name: disk3
Product ID: 0x9800
Vendor ID: 0xf055
Version: 2.00
Volumes:
NO NAME:
Capacity: 112 KB
Available: 70 KB
Writable: Yes
BSD Name: disk3s1
Volumes:
disk3s1:
Capacity: 112 KB
Available: 70 KB
Writable: Yes
Hi there,
Also having some problems . Macbook 10.6.8
Open a terminal and
screen /dev/tty.usbmodem*
A message comes up about being unable to as it doesn't exist then it reverts back to the Terminal screen, now with [screen is terminating] under the previous line.
board mounts and ejects ok. have re-booted mac and reset Micropython board
Any help would be appreciated
ta
Open a terminal and
ta
You need to provide the specific device name that the pyboard configures as - the asterisk '*' is just a wild card for a string of numbers and letters.milkybar_ton wrote: Open a terminal and
You can type 'ls /dev/tty.usbmodem*' at the command prompt to get the actual device name.
Depending on which usb port I plug in to on my computer, my pyboard appears as either '/dev/tty.usbmodem1a22' or '/dev/tty.usbmodem1d12'
I would guess that if I connected using a hub I might even get different names, but I haven't tried that yet.
Thanks for the info, still having problems however
"You can type 'ls /dev/tty.usbmodem*' at the command prompt to get the actual device name." i get a no such file or directory reply to this.
if i df -h then i get
/dev/disk1s1 95Ki 20Ki 75Ki 22% /Volumes/NO NAME -This is my board
I've also tried replacing the tty.usbmodem* part with /disk1s1 but again no joy
Your patience is appreciated
cheers
cheers
There should be two new devices which appear in the /dev tree when you plug in- you are finding the mass storage device but not the serial device (/dev/tty.usbmodem*)
Replying from my phone at the moment, will try figure out what it is when I get to my computer. Meanwhile, can you see what 'dmesg' returns when you plug in your board?
Hi and thanks for the prompt reply. I get this :-
0 [Level 3] [ReadUID 0] [Facility com.apple.system.fs] [ErrType IO] [ErrNo 6] [IOType Write] [PBlkNum 55] [LBlkNum 55] [FSLogMsgID 1515363706] [FSLogMsgOrder First]
0 [Level 3] [ReadUID 0] [Facility com.apple.system.fs] [DevNode devfs] [MountPt /dev] [Path /dev/disk1s1] [FSLogMsgID 1515363706] [FSLogMsgOrder Last]
disk1s1: media is not present.
0 [Level 3] [ReadUID 0] [Facility com.apple.system.fs] [ErrType IO] [ErrNo 6] [IOType Write] [PBlkNum 43] [LBlkNum 43] [FSLogMsgID 1086214669] [FSLogMsgOrder First]
0 [Level 3] [ReadUID 0] [Facility com.apple.system.fs] [DevNode devfs] [MountPt /dev] [Path /dev/disk1s1] [FSLogMsgID 1086214669] [FSLogMsgOrder Last]
0 [Level 3] [ReadUID 0] [Facility com.apple.system.fs] [ErrType IO] [ErrNo 6] [IOType Write] [PBlkNum 1] [LBlkNum 0] [FSLogMsgID 499150781] [FSLogMsgOrder First]
0 [Level 3] [ReadUID 0] [Facility com.apple.system.fs] [DevNode /dev/disk1s1] [MountPt /Volumes/NO NAME] [FSLogMsgID 499150781] [FSLogMsgOrder Last]
USBMSC Identifier (non-unique): 000000000011 0xf055 0x9800 0x200
0 2 AppleUSBCDCACMData: start - Find CDC driver for data interface failed
dos2unixtime(): month value out of range (15)
After i have sudo dmesg. Don't know what any of this means, if you haven't already guessed i'm new to all this
ta
ta
Your problem is revealed here:
Edited to add: It looks like this is the same issue that the OP for this thread has; one running 10.5.x and one running 10.6.x
Anyone else running older OS X versions seeing the same issue? I am on 10.7 on a machine from 2007 and don't have this problem.
I had the impression that OS X always had the CDC class driver available, but I'm not an expert in this. I'll try to look into it.USBMSC Identifier (non-unique): 000000000011 0xf055 0x9800 0x200
I did some poking around, and apparently earlier versions of the Apple CDC driver were less tolerant of certain descriptors.
I don't have a Mac to test this with but I found this:
http://www.opensource.apple.com/source/ ... ontrol.cpp
If you search for CM_ManagementData you'll see that they had early returns if the capabilities bits for CM_ManagementData (0x01) or CM_ManagementOnData (0x02) are zero.
It looks like these capabilities bits are defined in the following places (the lines that mention "bmCapabilities: D0+D1")
https://github.com/micropython/micropyt ... cdc.c#L221
https://github.com/micropython/micropyt ... cdc.c#L317
https://github.com/micropython/micropyt ... cdc.c#L409
https://github.com/micropython/micropyt ... hid.c#L104
https://github.com/micropython/micropyt ... _msc.c#L88
https://github.com/micropython/micropyt ... hid.c#L123
https://github.com/micropython/micropyt ... hid.c#L260
Looking in my build directory, I only see the following object file: build-PYBV10/usbdev/class/cdc_msc_hid/src/usbd_cdc_msc_hid.o which would imply that you only need to change stmhal/usbdev/class/cdc_msc_hid/src/usbd_cdc_msc_hid.c (lines 123 and 260).
I'd try changing the 0x00 to be 0x03 and see if that makes any difference.
