SPI Test
Posted: Mon Mar 21, 2016 3:06 pm
by mschulz
to test the SPI Bus, I connectet the X and Y pins.
X8 MOSI -> Y8 MOSI
X7 MISO -> Y7 MISO
X6 SCK -> Y6 SCK
With my code I want send wit SPI X a message to SPI Y and print it.
But I get an OSERROR 116. Why? Where is my mistake?
What must I do with the Slave Select (SS)?
When I connect MISO mit MOSI bei SPI X, I can send and recive a message.
print ('INIT des Schalters')
switch = pyb.Switch()
spi = pyb.SPI(1, pyb.SPI.MASTER, baudrate=600000, polarity=1, phase=0, crc=0x7)
spi2 = pyb.SPI(2, pyb.SPI.SLAVE, baudrate=600000, polarity=1, phase=0, crc=0x7)
buf = bytearray(4)
buf2 = bytearray(4)
print('send 1234 ')
spi.send(b'1234')
#print('buf',buf)
print(' empfange in buf')
print('buf',spi2.recv(4))
#print('send 1357 und empfange in buf')
#spi.send_recv(b'1357',buf)
#print('buf',buf)
Thank you for your help.
Re: SPI Test
Posted: Mon Mar 21, 2016 6:00 pm
OSError 116 is a timeout. You need to connect the master SS to the slave SS - in master mode the firmware should configure SS as an output, and in slave mode it should be an input. I'd be tempted to use a resistor (say 470 ohm to 1K) to make the connection in initial testing in case they somehow both end up as outputs. You may be treading new ground here - people have tried I2C in slave mode but I can't find any references in the forum to anyone using slave mode SPI.
