uart problem
wwsheldons
uart problem
Post by wwsheldons » Sat Apr 16, 2016 3:34 am
Does the micropython support the receive interruption of uart? And the API function is what? thank you
Re: uart problem
Post by dhylands » Sat Apr 16, 2016 3:46 am
When the read_buf_len (argument to the init function) is non-zero, then interrupts enabled to put received characters into the buffer.
The default is a read_buf_len of 64.
wwsheldons
Re: uart problem
Post by wwsheldons » Sat Apr 16, 2016 5:16 am
thank you :D :D
wwsheldons
Re: uart problem
Post by wwsheldons » Sat Apr 16, 2016 5:22 am
And the callback function is...?
Re: uart problem
Post by pythoncoder » Sat Apr 16, 2016 6:00 am
There isn't a user callback. The UART performs I/O using interrupts in the background. You need to poll the any() method to determine how many characters are in its buffer.
Re: uart problem
Post by dhylands » Sat Apr 16, 2016 6:05 am
You can also use select on the uarts.
wwsheldons
Re: uart problem
Post by wwsheldons » Sun Apr 17, 2016 12:21 am
dhylands wrote:You can also use select on the uarts.
thanks , and do you give me an example?
wwsheldons
Re: uart problem
Post by wwsheldons » Sun Apr 17, 2016 2:51 am
thank you very much! :geek: :geek:
