uart problem
uart problem
Does the micropython support the receive interruption of uart? And the API function is what? thank you
Re: uart problem
When the read_buf_len (argument to the init function) is non-zero, then interrupts enabled to put received characters into the buffer.
The default is a read_buf_len of 64.
Re: uart problem
And the callback function is...?
Re: uart problem
There isn't a user callback. The UART performs I/O using interrupts in the background. You need to poll the any() method to determine how many characters are in its buffer.
Re: uart problem
dhylands wrote:You can also use select on the uarts.
thanks , and do you give me an example?
