Timer callback problem
stmfresser
Post by stmfresser » Mon Sep 12, 2016 6:10 pm
i'm trying to toggle the leds every 1 second. i get the this error message
uncaught exception in Timer(2) interrupt handler
TypeError: function takes 1 positional arguments but 2 were given
import micropython
micropython.alloc_emergency_exception_buf(200)
class A:
	def __init__(self):
		self.leds = [pyb.LED(i) for i in range(1,5)]
		tim = pyb.Timer(2, freq=1)
		tim.callback(self.ledToggle)
	def ledToggle(self):
		for led in self.leds:
			led.toggle()
if __name__ == '__main__':
	a = A()
does anyone know how to solve it?
thanks in advance
Re: Timer callback problem
Post by deshipu » Mon Sep 12, 2016 6:36 pm
I think the ledToggle callback needs to take a parameter.
Post by dhylands » Mon Sep 12, 2016 6:38 pm
Yep - see an example here (that also uses classes):
https://github.com/dhylands/upy-example ... eat_irq.py
stmfresser
Post by stmfresser » Mon Sep 12, 2016 7:01 pm
dhylands wrote:Yep - see an example here (that also uses classes):
thanks.
now i get a another error message
MemoryError: memory allocation failed, heap is locked
micropython runs on a STM32F407 Discovery Board
MicroPython v1.8.3-26-ga56a683 on 2016-08-16; F4DISC with STM32F407
Post by dhylands » Mon Sep 12, 2016 10:35 pm
You should read this: http://docs.micropython.org/en/latest/p ... =interrupt
You're not allowed to allocate memory inside an interrupt handler (and timer callbacks are interrupt handlers).
The for loop is trying to allocate an iterator object. If you rewrite it like this:
import micropython
class A:
   def __init__(self):
   def ledToggle(self, tim):
      for i in range(len(self.leds)):
         self.leds[i].toggle()
A()
stmfresser
Post by stmfresser » Mon Sep 12, 2016 11:56 pm
dhylands wrote:You should read this: http://docs.micropython.org/en/latest/p ... =interrupt
import micropython
class A:
   def __init__(self):
A()
Thank you!
