Mark it as "[SOLVED]"kevinkk525 wrote: ↑Tue Sep 18, 2018 7:39 pmThanks for looking into this. I don't know what changed, but now it looks like most of the RAM is freed after removing of modules.. bit weird.
Remove imported module from RAM
Re: Remove imported module from RAM
Well, wanted to when I realized that it is behaving completely random and often even does not work correctly:
It's the same test that I did before, which worked at that time.
The testmodule just contains this:
It behaves completely random. At one point, it frees up everything except a couple Bytes, the next time it frees up everything except 130Bytes (and that's only a small module).
Oh and I can't mark it solved as it is not my thread (and now it is not completeley solved in my opinion, although I don't know what to do with this problem..)
>>> import gc
>>> import sys
>>> gc.collect();gc.mem_free()
4272
4240
>>> import pysmartnode.testmodule
testmodule imported
hi there
3824
3824
>>> del pysmartnode.testmodule
>>> del sys.modules["pysmartnode.testmodule"]
4000
4000
3952
print("testmodule imported")
print("hi there")
class Lock:
def __init__(self):
self._locked = False
async def __aenter__(self):
if self._locked:
await asyncio.sleep_ms(_DEFAULT_MS)
self._locked = True
break
async def __aexit__(self, *args):
def locked(self):
return self._locked
l = Lock()
Kevin Köck
After import pysmartnode.testmodule, insert a dir()kevinkk525 wrote: ↑Tue Sep 18, 2018 7:58 pmWell, wanted to when I realized that it is behaving completely random and often even does not work correctly:
It's the same test that I did before, which worked at that time.Code: Select all
>>> import gc >>> import sys >>> gc.collect();gc.mem_free() 4272 >>> gc.collect();gc.mem_free() 4240 >>> import pysmartnode.testmodule testmodule imported hi there >>> gc.collect();gc.mem_free() 3824 >>> gc.collect();gc.mem_free() 3824 >>> del pysmartnode.testmodule >>> del sys.modules["pysmartnode.testmodule"] >>> gc.collect();gc.mem_free() 4000 >>> gc.collect();gc.mem_free() 4000 >>> gc.collect();gc.mem_free() 3952 >>>
It behaves completely random. At one point, it frees up everything except a couple Bytes, the next time it frees up everything except 130Bytes (and that's only a small module).Code: Select all
print("testmodule imported") print("hi there") class Lock: def __init__(self): self._locked = False async def __aenter__(self): while True: if self._locked: await asyncio.sleep_ms(_DEFAULT_MS) else: self._locked = True break async def __aexit__(self, *args): self._locked = False await asyncio.sleep_ms(_DEFAULT_MS) def locked(self): return self._locked l = Lock()
I tried it again on an empty setup (just in case) and it behaves similar.
In your example you had only ~50Bytes not freed up, I have 100-200Bytes not freed. Multiple tests did not change that.
>>> import gc
>>> import sys
22480
testmodule imported
hi there
22080
>>> dir()
['pysmartnode', 'gc', '__name__', 'uos', 'sys', 'main']
22048
22288
>>> dir()
['pysmartnode', 'gc', '__name__', 'uos', 'sys', 'main', 'a']
>>> del pysmartnode
>>> del sys.modules["pysmartnode"]
22320
22368
Kevin Köck
You're never gonna get 100% of the memory freed because when you run commands in REPL, like dir(), that will also allocate memory.kevinkk525 wrote: ↑Tue Sep 18, 2018 8:46 pmI tried it again on an empty setup (just in case) and it behaves similar.
In your example you had only ~50Bytes not freed up, I have 100-200Bytes not freed. Multiple tests did not change that.Code: Select all
>>> import gc >>> import sys >>> gc.collect();gc.mem_free() 22480 >>> import pysmartnode.testmodule testmodule imported hi there >>> gc.collect();gc.mem_free() 22080 >>> dir() ['pysmartnode', 'gc', '__name__', 'uos', 'sys', 'main'] >>> gc.collect();gc.mem_free() 22048 >>> del pysmartnode.testmodule >>> del sys.modules["pysmartnode.testmodule"] >>> gc.collect();gc.mem_free() 22288 >>> dir() ['pysmartnode', 'gc', '__name__', 'uos', 'sys', 'main', 'a'] >>> del pysmartnode >>> del sys.modules["pysmartnode"] >>> gc.collect();gc.mem_free() 22320 >>> gc.collect();gc.mem_free() 22368
When you call dir(), a list is allocated and populated which uses heap.
And I see you've recognized that import a.b means you need to call del b and not del a.b (and same thing with del sys.modules["b"])
The only thing you can do to free memory occupied by mod is:
del mod
del sys.modules["mod"]
gc.collect()
import mod
a = mod
del mod
gc.collect()
[Solved] Re: Remove imported module from RAM
I understand that I don't get 100% back and especially in repl there can be allocations. Also I tried to not have any references left to the module I remove.
I tried to implement that strategy into my bigger programs and sometimes I end up getting almost no RAM back, which many of my smaller tests confirmed while others worked perfectly. Just tried it with a bigger (1kb) module and got everything back except 60Bytes. So it does theoretically work.
Guess I have to check it more carefully in my project, maybe I do have references I'm not aware of.
Kevin Köck
I'm having troubles again.. Thanks for looking at it in advance.
Was trying to implement unloading modules into my project so I could run some functions and then unload that module to free up the RAM as I won't need that functions again. So I split one module into 2 in order to unload one after usage.
But apparently I'm completely unable to unload that module even when I only load this module directly.
In normal usage RAM even drops by almost 1kB. The manual tests reveals that RAM drops too, unless I remove the root package "pysmartnode" which is used by other loaded modules as well, so I can't juist delete the root package from sys.modules (I guess?).
The content of pysmartnode.networking.mqtt_receive_config is this:
>>> import gc
>>> import sys
22416
>>> sys.modules
{'pysmartnode': <module 'pysmartnode'>, 'pysmartnode.main': <module 'pysmartnode.main'>, 'main': <module 'main'>}
22368
>>> from pysmartnode.networking import mqtt_receive_config
18048
18048
>>> del mqtt_receive_config
>>> del sys.modules["pysmartnode.networking.mqtt_receive_config"]
17952
17952
>>> del sys.modules["pysmartnode.networking"]
17920
18400
import uasyncio as asyncio
import json
_mqtt = None
_log = None
_awaiting_config = False
_has_failed = False
_has_succeeded = False
_config = None
_pyconfig = None
async def requestConfig(config, mqtt, log):
global _log
_log = log
global _mqtt
_mqtt = mqtt
global _pyconfig
_pyconfig = config
if _awaiting_config:
return
asyncio.get_event_loop().create_task(_receiveConfig(log))
await asyncio.sleep_ms(200)
if _has_failed:
return False
elif _has_succeeded:
return _config
async def _awaitConfig(topic, msg, retain):
_log.info("Building components", local_only=True)
await _mqtt.unsubscribe("{!s}/login/".format(_mqtt.mqtt_home) + _mqtt.id)
if type(msg) != dict:
_log.critical("Received config is no dict")
msg = None
if msg is None:
_log.error("Empty configuration received")
global _has_failed
_has_failed = True
return
_log.info("received config: {!s}".format(msg), local_only=True)
# saving components
_pyconfig.saveComponentsFile(msg)
global _config
_config = json.dumps(msg)
global _has_succeeded
_has_succeeded = True
return
async def _receiveConfig(log):
global _awaiting_config
_awaiting_config = True
log.info("Receiving config", local_only=True)
await _mqtt.subscribe("{!s}/login/{!s}".format(_mqtt.mqtt_home, _mqtt.id), _awaitConfig, qos=1,
check_retained=False)
log.debug("waiting for config", local_only=True)
await _mqtt.publish("{!s}/login/{!s}/set".format(_mqtt.mqtt_home, _mqtt.id), _pyconfig.VERSION, qos=1)
t = time.ticks_ms()
while (time.ticks_ms() - t) < 10000:
if not _has_succeeded:
return
if _has_failed:
return
Kevin Köck
I don’t know what your question is.
my question is:
What am I doing wrong that I don't get any RAM back from this module?
(Unless I remove the root package "pysmartnode" but this is used by every other module too, so I don't know if I should remove that? But even doing so does not give me the RAM back when outside the manual test. I now splitted a module into 2 so I can unload one module but instead I end up with 1kB less free RAM than before when it was one module.)
Kevin Köck
kevinkk525 wrote:my question is:
We went over this. Scroll up.
If you
import some.thing
you have to do
del thing
del sys.modules[“thing”]
