Hello, i found numerous questions here about the WiPy timer class, but most of them was before the 1.6 release. However i still couldn't make it work. I have a wipy with the latest framework(1.8.2). I tried all the examples from the docs, here are my tries:
[CODE]
tim = Timer(1, mode=Timer.PERIODIC, width=32)
tim_a = tim.channel(Timer.A | Timer.B, freq=1) # 1 Hz frequency requires a 32 bit timer
def tick(timer): # we will receive the timer object when being called
f = open('abc.txt', 'w')
f.write('it_works')
f.close() # toggle the LED
print('timerTicked')
tim_a.irq(handler=tick, trigger=Timer.TIMEOUT)
[/CODE]
[CODE]
led = Pin('GP16', mode=Pin.OUT) # enable GP16 as output to drive the LED
tim = Timer(3) # create a timer object using timer 3
tim.init(mode=Timer.PERIODIC) # initialize it in periodic mode
tim_ch = tim.channel(Timer.A, freq=5) # configure channel A at a frequency of 5Hz
tim_ch.irq(handler=lambda t:led.toggle(), trigger=Timer.TIMEOUT) # toggle a LED on every cycle of the timer
[/CODE]
I tried the other basic examples also, none of them seemed to work for me, but i dont get any errors either, could someone help me out?
WiPy Timer
Re: WiPy Timer
I had some problems with the Timers not so long ago, also trying the examples. Unfortunately, I do not see what is wrong in your code, but I can show what is working on my WiPy now.
Currently using the Pycom firmware (MicroPython v1.8.2-103-g834e021), but will move to the official MicroPython when I get the time...
I have added this code to a file called nr.py:
To test this:
Hope it helps,
counter_timer_callback = 0 # Count number of timer callbacks
# Create timer callback function
def timer_callback(timer):
global counter_timer_callback
counter_timer_callback += 1
# Configure timer with callback to enable temperature measurements
# at fixed intervals
def timer_init():
temperature_init()
tim = Timer(1, mode = Timer.PERIODIC, width = 32)
tim_ch = tim.channel(Timer.A | Timer.B, freq = 2)
tim_ch.irq(handler = timer_callback, trigger = Timer.TIMEOUT)
print('timer initialised')
# Wait for counter_timer_callback to reach 120
def timer_wait_for_120():
while(1):
if (counter_timer_callback > 120):
temperature_read()
print('temperature read')
>>> import nr
>>> nr.timer_init()
timer initialised
>>> nr.timer_wait_for_120()
temperature read <--- This repeats every minute
Re: WiPy Timer
I have no idea what was wrong with mine, but this one works, thank you so much!
