Sonoff: IRQ on push-button
BigMan
Post by BigMan » Sat Dec 17, 2016 12:12 pm
I was able to flash a Sonoff device with MicroPython. This Sonoff should switch a lamp on/off. Everyhing works fine and now I want to implement a back-up function, in case my wlan is not available. The idea is to make use of the push-button on the Sonoff. I was already able to define it as an interrupt to turn directly the lamp on/off. The code is pretty simple:
pinRelay = machine.Pin(12, machine.Pin.OUT)
pinSchalter = machine.Pin(0, machine.Pin.IN, machine.Pin.PULL_UP)
def umschalten(p):
    pinRelay.value(not pinRelay.value())
pinSchalter.irq(trigger=machine.Pin.IRQ_FALLING, handler=umschalten)
Next, I want to give this push-button a further functionality: to reboot the Sonoff:
- push-button pressed less than 2sec. -> just switch the relay
- push-button pressed/hold longer than 2sec -> reboot the Sonoff
For this I changed the callback-function to this:
def umschalten(p):
    zeitschleife = 0
    time.sleep_ms(500)
    while pinSchalter == 0:
        if zeitschleifer >= 100:
            machine.reset()
        time.sleep_ms(20)
        zeitschleife += 1
But it is not working. When I press and hold the push-button it never makes the machine.reset(). Always it is switching the relay.
I ASSUME, it is because of the bouncing-beviour of the push-button. Any ideas?
Frida
Re: Sonoff: IRQ on push-button
Post by Frida » Sat Dec 17, 2016 3:36 pm
Boiled down, should if zeitschleifer >= 100:, not be if zeitschleife >= 100:
My bet.
Yes Frida is my watchdog!
BigMan
Post by BigMan » Sat Dec 17, 2016 4:00 pm
Frida wrote:Boiled down, should if zeitschleifer >= 100:, not be if zeitschleife >= 100:
My bet.
uppp ... yes this is a mistake.
But even after I fixed this, it is still not working.
Updated code:
def umschalten(p):
    zeitschleife = 0
    time.sleep_ms(500)
            machine.reset()
        time.sleep_ms(20)
        zeitschleife += 1
Frida
Post by Frida » Sat Dec 17, 2016 5:00 pm
On my wipy1, I can run this:
# on wipy1
import micropython
#pinRelay = machine.Pin(12, machine.Pin.OUT)
#pinSchalter = machine.Pin(0, machine.Pin.IN, machine.Pin.PULL_UP)
pinRelay=Pin('GP16');pinRelay.value(1);pinRelay.mode(1) #set led off
pinSchalter=Pin('GP17', Pin.IN, Pin.PULL_UP)
def umschalten(p):
    zeitschleife = 0
    time.sleep_ms(500)
    print('her går det godt!')
    while pinSchalter() == 0:
        print('Schalter=0')
            #machine.reset()
			print('machine.reset')
        time.sleep_ms(20)
        zeitschleife += 1
BigMan
Post by BigMan » Sat Dec 17, 2016 8:04 pm
Frida wrote:On my wipy1, I can run this:
# on wipy1
import micropython
def umschalten(p):
    zeitschleife = 0
    time.sleep_ms(500)
        print('Schalter=0')
            #machine.reset()
        time.sleep_ms(20)
        zeitschleife += 1
Looks for me exactly like my code ... or? Is it working on your wipy?
However, if it is exactly like my code, on my Sonoff it's not working.
Frida
Post by Frida » Sat Dec 17, 2016 8:26 pm
I have changed your pin to pins for wipy1:
changed:
to:
inserted:
changed:
         #machine.reset()
so I could see what happend.
Yes it runs on my wipy1.
If it still dosn't work, let me see the whole programm, so we can get it to work.
BigMan
Post by BigMan » Sat Dec 17, 2016 9:40 pm
Frida wrote: changed:
to:
ahh ... how could I oversee that. Sure. Now, I changed it to >>while pinSchalter.value() == 0:<< and it basically work.
(I am only still getting the Message "NameError:" when I press it less than 2Sec. But perhaps it is related with another piece of the code.
Let me sleep over it. Perhaps this is also just because of a stupid typo which I currently don't see with my sleepy eyes.
