OSError: accelerometer not found
MJA-AJM
Post by MJA-AJM » Thu Jan 12, 2017 4:38 pm
I write in Serial Terminal:
pyb.Accel()
Answer is:
Can anyone tell me what I do wrong?
Re: OSError: accelerometer not found
Post by dhylands » Thu Jan 12, 2017 5:48 pm
Which board are you using?
MJA-AJM
Post by MJA-AJM » Sun May 07, 2017 12:45 pm
My bad bought the cheep model without one.
vince
Post by vince » Wed Sep 16, 2020 12:35 pm
I've got the same error, although I use a Pyboard v 1.1, and it should have one :o :
https://store.micropython.org/product/PYBv1.1H
Any idea whats wrong? Does it needs to be switched on first or something similar? :?:
Post by pythoncoder » Thu Sep 17, 2020 11:00 am
On a Pyboard 1.1 you should be able to issue at the REPL
>>> import pyb
>>> a = pyb.Accel()
>>> a.filtered_xyz()
The last line should return something like (2, -7, 22). If you get an error please post it.
JulioFD1972
Post by JulioFD1972 » Wed Jan 06, 2021 6:08 pm
Good afternoom,
I have the same problem. I have the pyboard v1.1
this is what I get.
>>> import pyb
>>> a=pyb.Accel()
Post by dhylands » Wed Jan 06, 2021 7:45 pm
Are you sure you have a 1.1 board? The 1.0 LITE board doesn't have an accelerometer.
What does:
import os
os.uname()
report for you?
Post by pythoncoder » Thu Jan 07, 2021 3:05 pm
There are also clone boards out there of dubious quality.
