Implementing SPI on the UNIX port
Turbinenreiter
Post by Turbinenreiter » Sat Jan 28, 2017 10:15 pm
I started implementing SPI on the UNIX port for the Raspberry Pi, but I'm not having much luck.
I get this compiler error:
machine_spi.c:205:5: error: initialization from incompatible pointer type [-Werror]
     .init = mp_machine_lspi_init,
But the code looks exactly like it does in the other SPI implementations.
STATIC void mp_machine_lspi_init(mp_obj_base_t *self_in, mp_int_t baud)
STATIC const mp_machine_spi_p_t mp_machine_spi_p = {
    .deinit = NULL,
    .transfer = machine_spi_transfer,
Any ideas?
Re: Implementing SPI on the UNIX port
Post by deshipu » Sat Jan 28, 2017 10:22 pm
You need the macro that actually defines the mp function, which is usually just below the function.
Turbinenreiter
Post by Turbinenreiter » Sun Jan 29, 2017 10:17 am
It's not there in extmod/machine_spi.c where I copied from either.
line 289, 330:
https://github.com/micropython/micropyt ... hine_spi.c
Post by deshipu » Sun Jan 29, 2017 11:21 am
Ah, but that expects a completely different function signature than what you have.
Turbinenreiter
Post by Turbinenreiter » Sun Jan 29, 2017 11:53 am
Yeah, that makes sense. I thought I could use it without arguments to quickly test it, didn't think about it actually having a defined interface.
I'm going to try a different route today, doing it in Python, based on this: https://github.com/vsergeev/python-periphery
Turbinenreiter
Post by Turbinenreiter » Sun Jan 29, 2017 3:43 pm
So python-periphery _works_.
There is some modifications to be done, mostly because of ctypes vs. uctypes also some weirdness with ioctl.
I have to press on with other work (I need to finish a paper, and I wanted to have this running for that), but as soon as I have time I will seriously look into implementing machine for unix based on python-periphery.
