Noob question on Modules
Hi All,
I have a question on using Micropython modules sourced from PyPI.
I have several esp8266 (Wemos D1 mini) boards which I have flashed with the Micropython firmware and have been using to improve my Python ability.
However, I have a question on using Micropython modules from Pypi, such as the https://pypi.python.org/pypi/micropytho ... mple/1.3.2 module. On a normal Python dev system, such as a Raspberry Pi, I'd just use virtualenv or pip install micropython-umqtt.simple and then use an import.
This obviously doesn't work on these boards, so I'm looking for some guidance on using these modules.
I believe that I could simply copy the .py files to the root filesystem of the board, but I'm just wondering on the above module as it actually is a umqtt directory with simple.py in it. Would I recreate that on the board filesystem, and if so, how would I import the module?
I was under the impression that the .py file name would have to match the module name so in this case would I import simple?
I know we have plenty of space for storing the modules on the board, my questions revolve mostly about getting them on the board and then calling them in my code in the most efficient manner.
Thanks for any help you can give me.
Stef
Stef
Re: Noob question on Modules
Yes, create a "umqtt" directory on the esp8226 and copy "simple.py" into it. Then import with:spynappels wrote: I believe that I could simply copy the .py files to the root filesystem of the board, but I'm just wondering on the above module as it actually is a umqtt directory with simple.py in it. Would I recreate that on the board filesystem, and if so, how would I import the module?
from umqtt.simple import whatever
from umqtt_simple import whatever
@SpotlightKid For the first method to work the umqtt directory would need to contain a file __init__.py
The file may be empty, but marks the directory as containing a Python package.
Are you sure? AFAIK Python 3 doesn't require "__init__.py" files anymore.
I always just used the second method myself, though.
Thanks for the responses guys, I'll try that and see how I get on. I assume that the directory including the __init__.py file is the "proper" way to do it?
In any case, the first method is the way to go, if you want to have other modules in the "umqtt" namespace, which you would then copy into the same directory and import with:
from umqtt.something import whatever
@SpotlightKid The docs for Python 3.3.6 https://docs.python.org/3.3/tutorial/mo ... l#packages states "The __init__.py files are required to make Python treat the directories as containing packages...".
Then these docs are out of date.
Micropython (being a Python 3 implementation), agrees with me:
$ mkdir -p test/spamm
$ cd test
$ echo "get_spamm = lambda: 'Spamm, Spamm, Spamm'" > spamm/ham.py
$ MICROPYPATH=. micropython
MicroPython v1.8.7-187-gbd04ed3e8 on 2017-02-04; linux version
>>> from spamm.ham import get_spamm; get_spamm()
$ rshell -p /dev/ttyUSB0 -b 115200 mkdir /flash/spamm
Connecting to /dev/ttyUSB0 ...
$ rshell -p /dev/ttyUSB0 -b 115200 repl
Entering REPL. Use Control-X to exit.
MicroPython v1.8.7-170-gb32880bd on 2017-02-01; ESP module with ESP8266
paste mode; Ctrl-C to cancel, Ctrl-D to finish
=== with open('spamm/ham.py', 'w') as fp:
=== fp.write('get_spamm = lambda: "Spamm, Spamm, Spamm"\n')
42
Thanks for that - I stand corrected. So much for the official docs
I'm a little bit surprised myself that the official tutorial is inaccurate. But then again it has been around since the early nineties!
