MQTT check_msg() Assertion Error - Bug ?
devnull
Postby devnull » Fri Feb 24, 2017 1:52 am
I am using the check_msg() to retrieve any waiting messages, and it crashes whenever it receives one.
I suspect that the cause is the QOS which is set on the incoming message and the umqtt_simple library is not handling it ??
checking...
  File "dev/mqtest.py", line 32, in <module>
  File "dev/mqtest.py", line 20, in connect
  File "/lib/umqtt_simple.py", line 192, in check_msg
  File "/lib/umqtt_simple.py", line 185, in wait_msg
AssertionError:
Who is online
Users browsing this forum: kfricke and 2 guests
