Why does this crash after 5 activations?
brett
Postby brett » Tue Feb 28, 2017 12:36 am
Forgive me for posting this again as a new topic.
Ok…I’m still struggling. The program will send both a help request and an emergency request. Where it gets weird is when you make 5 consecutive activations of combinations of help and emergency requests.
I’ve tried these combinations:
Help, help, help, help, help
Emergency, help, help, help, help
Help, emergency, emergency, emergency, emergency
Emergency, help, Emergency, help, Emergency
Help, emergency, help, emergency, help
After these combinations I get the following error message:
File "main.py", line 61, in <module>
File "urequests.py", line 104, in post
File "urequests.py", line 51, in request
OSError: -2
After the second emergency request I get the following error message:
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
load 0x40100000, len 32028, room 16
tail 12
chksum 0x40
ho 0 tail 12 room 4
load 0x3ffe8000, len 1092, room 12
tail 8
chksum 0x17
load 0x3ffe8450, len 3000, room 0
tail 8
chksum 0x56
csum 0x56
Any thoughts and suggestions? Here is the current code:
import urequests
wlan.active(True)
wlan.connect('xxxxxxxxxxxx', 'xxxxxxxxxx')
button = machine.Pin(14, machine.Pin.IN, machine.Pin.PULL_UP)
redled = machine.Pin(5, machine.Pin.OUT)
yelled = machine.Pin(12, machine.Pin.OUT)
grnled = machine.Pin(4, machine.Pin.OUT)
url_01 = 'http://api.pushingbox.com/pushingbox?devid=xxxxxxxxxxxxxxx'
url_02 = 'http://api.pushingbox.com/pushingbox?devid=xxxxxxxxxxxxxx'
buttonCounter = 0
helpFlag = False
def helpRequest():
    if buttonCounter == 1:
        global helpFlag
        helpFlag = True
    elif buttonCounter == 2:
        global helpFlag
        helpFlag = True
def emergencyRequest():
    print('Emergency')
    resp = urequests.post(url_02)
    redled(1)
    tim2 = Timer(1)
    tim2.init(period=10000, mode=Timer.ONE_SHOT, callback=lambda t:redled(0))
def buttonReset(self):
    helpRequest()
    global buttonCounter
    buttonCounter = 0
    print('reset')
    print(buttonCounter)
    first = button.value()
    time.sleep(0.05)
    second = button.value()
    if first and not second:
        print('Button pressed!')
        buttonCounter = buttonCounter + 1
        tim3 = Timer(2)
        tim3.init(period=2000, mode=Timer.ONE_SHOT, callback=buttonReset)
    if buttonCounter >= 3:
        emergencyRequest()
        buttonCounter = 0
    if helpFlag == True:
        resp = urequests.post(url_01)
        helpFlag = False
        print('Help 2')
        yelled(1)
        tim = Timer(-1)
        tim.init(period=10000, mode=Timer.ONE_SHOT, callback=lambda t:yelled(0))
    if wlan.isconnected() == True:
        grnled(1)
    elif wlan.isconnected() == False:
        grnled(0)
Re: Why does this crash after 5 activations?
Postby pythoncoder » Wed Mar 01, 2017 7:14 am
I can't see anything obviously wrong, although I do think the code has scope for simplification.
I'd concentrate on the simplest case which is a failure after five help requests. The question which comes to mind is whether this results from the WiFi comms. To check this I'd write a simple loop which issues a number of help requests:
for _ in range(10):
    time.sleep(3)
If this crashes it proves that the fault is in the comms rather than the program logic. Is there a server issue? Is the WiFi flaky?
If it doesn't crash then the fault is presumably in the program logic. I'd then comment out the urequests, replacing them with print statements, and set about debugging the logic.
Postby pythoncoder » Wed Mar 01, 2017 7:51 am
I couldn't resist simplifying this ;) The following is untested so may have bugs, but at least it gives the gist of how the code might be simplified.
button_counter = 0
run_flag = False
def run(t):
    global run_flag
    run_flag = True
    global run_flag, button_counter
    time.sleep(0.05)
    if first and not button.value():
        button_counter += 1
        print(button_counter)
        tim3 = Timer(-1)
        tim3.init(period=2000, mode=Timer.ONE_SHOT, callback=run)
    if run_flag:
        run_flag = False
        if button_counter >= 3:
            print('Emergency')
            redled(1)
            tim2 = Timer(-1)
        else:  # At least one button must have been pressed to get here
            print('Help')
            yelled(1)
            tim = Timer(-1)
        button_counter = 0
    grnled(wlan.isconnected())
Note that I'm using virtual timers throughout.
Return to “General Discussion and Questions”
Who is online
Users browsing this forum: No registered users and 2 guests
