Simulating hardware for micropython application
BrendanSimon
Post by BrendanSimon » Sun Mar 05, 2017 10:29 am
Just wondering what the best way to simulate micropython apps on a PC with a GUI (e.g. wxPython Phoenix). I'm thinking of things like keypads, LCDs, LEDs, buttons/switches, Analog input/output.
My work environment uses C for embedded and a Windows based C++ GUI framework to simulate the applications, including fake LCDs, keypads, LEDs, etc.
So how can I do the same with a micropython application (e.g. an STM32 board with a 4x4 keypad and a 20x4 I2C LCD)?
wxPython is probably my GUI of choice. Is it possible to use wxPython with micropython?
There must be a better way of port in a micropython app to CPython for simulation purposes (or vice versa).
The purpose of simulating is to run as much of the app in an easy to use environment for debugging etc, or if there is lack of hardware, etc. It makes sense to use micropython where possible if the target application is micropython.
Re: Simulating hardware for micropython application
Post by deshipu » Sun Mar 05, 2017 10:41 am
You can write your own version of the machine module, that would display stuff in the GUI instead of talking to the actual peripherals. It would be a lot of work, and you would probably need to have some way of configuring what is connected where, but it is certainly possible, and not even that hard.
BrendanSimon
Post by BrendanSimon » Sun Mar 05, 2017 10:57 am
Are you suggesting the `machine` module would be imported to a CPython (e.g. wxPython) app? i.e. the app is a normal python app with a special `machine` module?
Or maybe it runs in MicroPython but communicates with an another GUI app (C, python, java, ...), with comms via TCP/IP, pipes, sharedmem, etc ???
Post by deshipu » Sun Mar 05, 2017 1:46 pm
No, MicroPython can run on Linux or Windows just fine, so you can run your programs with that, and only provide a mocked access to the peripherals that you wish to simulate.
SpotlightKid
Post by SpotlightKid » Sun Mar 05, 2017 1:57 pm
It would be very difficult, though, to get a full-featured GUI framework running under micropython, so I think the idea of making the machine module a proxy, that calls into a GUI process via some sort of RPC, is viable.
Post by dhylands » Sun Mar 05, 2017 5:42 pm
Yeah - it really depends on what level of abstraction you want.
I often make specialized classes for CPython versus MicroPython and have the code that uses those be regular python (CPython or MicroPython).
For example:
MicroPython serial over USB: https://github.com/dhylands/json-ipc/bl ... sb_port.py
CPython serial: https://github.com/dhylands/json-ipc/bl ... al_port.py
CPython serial over sockets: https://github.com/dhylands/json-ipc/bl ... et_port.py
I typically use the CPython serial over sockets for testing both sides on a PC.
I've also created fake pyb classes for testing: https://github.com/dhylands/bioloid3/blob/master/pyb.py and I've seen some other similar things.
BrendanSimon
Post by BrendanSimon » Mon Mar 06, 2017 5:39 am
I'm thinking the simplest thing is to just use CPython, with wxPytohn and standard Cpython modules, and fake the hardware of interest at high level API. This can be used to run/test basic application logic and user interaction, and then do final checking on real hardware with MicroPython.
This is not too different to what I've experienced in C land. It's analogous to using GCC or IAR compiled code on the target, and GCC/VisualStudio/Embarcadero build of or the code (with simulated hardware) for the Simulator.
If I wanted to actually run as much MicroPython code as possible, then I would have to use some kind of RPC/IPC with specialised modules in conjunction with a GUI app.
Thanks, Brendan.
