Lora support in MP?
Posted: Mon May 08, 2017 1:39 pm
by mark189
Hello there,
I'm new in MP and wonder if there is any support for Lora in MP?
Importing the "lora module" in MP is not possible
https://docs.pycom.io/lopy/library/netw ... class-lora
thanx
Re: Lora support in MP?
Posted: Mon May 08, 2017 5:41 pm
You'll probably get a better response by posting to the Pycom forum
https://forum.pycom.io/.
Posted: Wed May 10, 2017 1:57 pm
by mark189
Thanx Peter.
But I'm looking for a solution to work with Micropython and Lora on a Wemos or NODEMCU board. (esp8266)
Or is the use of the Lora module in Micropython only possible on a Lopy board?
regards
Mark
Posted: Thu May 11, 2017 5:51 am
LoRa is a radio link modulation standard and requires very specific radio hardware. As far as I'm aware the Pycom board is the only one with LoRa hardware and running MicroPython. You certainly can't get a LoRa signal out of an ESP8266...
Posted: Thu May 18, 2017 3:50 pm
by thetreerat
you can use the feather wing from adafruit to get the hardware, but I don't know if anyone has converted the libraries from adafruit to micropython. They also have a break out boards for the same chips that the feather wing is based on.
it was something I was going to start looking into soon as I almost have my project working on the wifi and need the extended range for far end controllers. however I have not had time yet. so if you find one can you post back?
Hal
