Embedding Micropython Interpreter as FreeRTOS Task
LorRed
Post by LorRed » Sun Jun 11, 2017 10:36 am
Hi everybody,
I am currently trying to embed Micropython in a bigger project based on an smt32f4 board.
Having set up FreeRTOS and some low level C task, I would like to place an high-level interpreter in a low priority task: so my choice of trying to include only Micropython as interpreter without any hal dependency.
First question: do you think it's possible to achieve this goal?
I have started from "Embedding Micropython example https://github.com/micropython/micropyt ... /embedding" trying to substitute unix minimal with arm minimal: not needing hal and ext modules I also removed few lines in the PY_O_BASENAME definition in the py.mk makefile. Eventually I am able to compile, getting a very big libmicropython.a (308Kb).
The mess happens when trying to link against the main project... :roll:
I get:
* (as expected) multiple definitions of memcpy, strlen...: my FreeRTOS project is compiled with -lc flag
* RAM overflow error from ld
I think I am not following the right path... any help would be appreciated.
braiins
Re: Embedding Micropython Interpreter as FreeRTOS Task
Post by braiins » Tue Jun 13, 2017 7:22 am
Would this do the job for you ;-)?
Jan
braiins - Your partner in embedded world - http://www.braiins.cz
LorRed
Post by LorRed » Wed Jun 14, 2017 9:37 am
Hi Jan,
this really looks like what I was looking for!
During my research I found a post of yours about Micropython + FreeRTOS but not this one :shock:
I am going to definitely try it in these days and let you know if it satisfies my needs, thank you.
