I've got problem with simple UART write,
when I try
ser = pyb.UART(2, 9600)
ser.write("test")
on my pyboard, and then connect tx and rx to the PC and open it using hyperteminal,
I've got garbled message :
(hex) 51 53 74 04 (str) QSt.
I am sure using correct uart settings (9600, 8-n-1).
any ideas?
[CLOSED] uart write garbled character
Last edited by ajie_dirgantara on Wed Jul 05, 2017 2:24 am, edited 1 time in total.
Re: uart write garbled character
Did you forget to also connect gnd?
How are you connecting the UART to the PC? What sort of adaptor are you using (e.g. FTDI USB adaptor)? I do hope you're not connecting to a PC serial port with a 9 or 25 way D-type connector. If you are, stop, hope no damage is done, and get an FTDI adaptor.
it is connected because REPL is running OK on another UARTdeshipu wrote:Did you forget to also connect gnd?
Last edited by ajie_dirgantara on Tue Jul 04, 2017 8:29 am, edited 1 time in total.
pythoncoder wrote:How are you connecting the UART to the PC? What sort of adaptor are you using (e.g. FTDI USB adaptor)? I do hope you're not connecting to a PC serial port with a 9 or 25 way D-type connector. If you are, stop, hope no damage is done, and get an FTDI adaptor.
yes I am using FTDI.. and also I think it is OK because REPL is working on another UART. I am not using USB.
Ok, If I am writing to UART3 (currently used by REPL) it shown OK on hyperterminal. but if I am using UART2, it shows garbled message. weird.
and, did I said I am using pyboard before?-- sorry, I mean I am using nucleo L476RG.
UPDATED :
The mistake are on me. I am NOT using correct FTDI usb to serial adapter. CASE CLOSED.
