Using micropython with arduino core
Is it possible to write a program in arduino core and have micropython at the same time? I want to have a scripting language, but can't write it entirely in python due to a bad performance. I know that I can embed C code in micropython, but can I use arduino libraries there?
Re: Using micropython with arduino core
There's a relatively new project to embed micropython into mbed-os. I find the mbed API and overall environmnet much more appealing than the Arduino one.
https://developer.mbed.org/users/infinn ... icropython
Have you looked at the @micropython.native and @micropython.viper decorators?
@micropython.native does not work on ESP32
The library I want to use is https://github.com/Bodmer/TFT_eSPI It works on Arduino. I don't want any other library since only this one gives the performance I want. Porting it is out of my skills ;/
Can't I put this library and arduino core for ESP32 together in stmhal?
Firstly stmhal is the branch for STM processors such as the Pyboard. It is irrelevant to the ESP32 which has a different processor architecture (Espressif).
There are two approaches which could be used, but both require some expertise. The approach I would use is to port the code to Python. If you can read C and write Python porting is straightforward donkey work.
The C code could in principle be ported so that it appeared as a native MicroPython module. In my opinion that would be more difficult, but that could reflect my own language preference. I think others will probably agree that with a library of that size it would require good C skills and an understanding of writing C modules for MicroPython. There is a fair amount of information on the latter topic in here.
The easy solution is to use a display where the donkey work has been done, for example the official LCD160CR module. Or search in here and in the Wiki for display drivers. There are quite a few...
