Line number of exception?
Is there any way to get the line number an exception occurred on in an except: clause? In CPython, I get it from the traceback returned by sys.exc_info(). I don't see exc_info in micropython's sys, or any way to get the traceback. I did see a define to disable line numbers in the build, so I'm half expecting they simply aren't available from python.
Re: Line number of exception?
Perhaps you could post some code. I can't see the problem.
Saving the same code as rats43.py:
$ upython
MicroPython v1.8.7-1080-g394c536-dirty on 2017-08-20; linux version
>>> try:
... 1/0
... except:
... 1/0
File "<stdin>", line 4, in <module>
ZeroDivisionError: division by zero
$ upython
>>> import rats43
File "rats43.py", line 4, in <module>
First question: do you know if those builds enabled MICROPY_ENABLE_SOURCE_LINE?
And the question I'm actually trying to get answered:
A line number alone won't get you far. Consider that you have 10 source files, how much information "exception is at line 15" gives you?
And how to capture a complete stacktrace, you can find in the documentation: http://docs.micropython.org/en/latest/p ... _exception .
Many other questions which may arise when using MicroPython can be answered by searching/reading the documentation too.
Awesome MicroPython list
Yes, but the documentation didn't answer my question either. That's why I asked.
So the only way to get information about an exception is to parse the traceback and how it doesn't change in the next revision?
