Copy of a dictionnary
Apollo22
Post by Apollo22 » Tue Aug 22, 2017 5:11 pm
I have a dictionnary that I want to copy into another to later check if any change was done in the first one. However dict.deepcopy() is not recognised and dict1 = dict(dict2) has the same effect as dict1 = dict2. Does anyone know a way around this ?
Re: Copy of a dictionnary
Post by dhylands » Tue Aug 22, 2017 6:31 pm
You can use copy() to create a shallow copy (tested on the unix version of micropython). There is a deepcopy implementation found in the copy module in micropython-lib:
https://github.com/micropython/micropyt ... py/copy.py
Apollo22
Post by Apollo22 » Wed Aug 23, 2017 8:17 am
I'm sorry I wasn't precise enough, I have a dictionnary inside a dictionnary, like that :
a['1'] = {
    'a' : 1,
    'b' : 2,
And in this case, if I do b = a.copy, and then change a, it changes b. But as I only have one entry in the first dictionnary, I can just do
b = a['1].copy()
deshipu
Post by deshipu » Wed Aug 23, 2017 5:55 pm
So you want deepcopy.
Post by pythoncoder » Thu Aug 24, 2017 4:43 am
Indeed. To me @dhylands resolved this query, unless I'm failing to grasp the problem.
marcwagner
Post by marcwagner » Wed Sep 19, 2018 6:04 pm
in python I would do:
[code] from copy import deepcopy
dict2 = deepcopy(dict1) [/code]
see: https://stackoverflow.com/questions/2465921/how-to-copy-a-dictionary-and-only-edit-the-copy
when I try this in micropython I get
[code]ImportError: no module named 'copy'[/code]
so what is the micropython way of doing this?
jickster
Post by jickster » Wed Sep 19, 2018 7:25 pm
see: https://stackoverflow.com/questions/246 ... t-the-copy
You have to add this .py file to micropython
because deepcopy is not builtin.
manseekingknowledge
Post by manseekingknowledge » Wed Jul 03, 2019 5:47 am
Based on your dict in a dict example it appears you are using only immutable objects (strings and integers), dicts, and lists in the thing you want to copy. If that is the case it would be much more efficient to do a json.dumps() followed immediately by a json.loads(). The deepcopy function has a lot of extra code that makes it inefficient for simple collections like those that can be represented by a JSON string. An additional bonus is that the json module is included in micropython by default.
import json
a_dict = {
    '1': {
        'a': 1,
        'b': 2
    '2': {
        'a': 3,
        'b': 4
copy_of_a_dict = json.loads(json.dumps(a_dict))
