Timer callback and infinite loop not playing
Posted: Thu Oct 30, 2014 4:11 pm
by Gordon_Hardman
A am new to Micropython, so forgive a noob question..
I am trying to have a system where most code executes in an infinite loop. A "background" timer runs at a 100msec rate, and the associated callback sets a flag, which is used in the infinite loop. I have seen on the forum that interrupts should not allocate memory, and perhaps not do other things, so I merely want to set a flag. I don't care precisely when the 100msec tasks are done, just that they get done around every 100 msec. The tasks, may grow in size and include all sorts of things, which might not play well with an interrupt, so I want to move them safely outside the interrupt.
The simplest code is attached. I see LED(1) toggling (on an o'scope!) but nothing else. It looks like maybe a scoping problem? Clearly hmsInt() is being called, so hmsFlag must be being set True. But it does not seem to be seen in the infinite loop. And no error messages.
Clearly imperfect understanding on my part, so any insights would help!
main.py -- put your code here!
hms = 0  # hundred msec ticks
hmsFlag = False
seconds = 0 # seconds
def hundredmsTasks():
    pyb.LED(2).toggle()
    if hms < 100:
        hms += 1
        hms = 0
        print("!")
def hmsInt():
    pyb.LED(1).toggle()
    hmsFlag = True
tim7 = pyb.Timer(7, freq=100)
tim7.callback(lambda t: hmsInt())
    if hmsFlag:
        hundredmsTasks()
        hmsFlag = False
    # other code goes here
Re: Timer callback and infinite loop not playing
Posted: Fri Oct 31, 2014 12:05 am
by dhylands
You need to add a couple of global statements.
def hmsInt():
    pyb.LED(1).toggle() # orange
    hmsFlag = True
In this version, hmsFlag is a local variable to the hmsInt function. If you change it to:
def hmsInt():
    global hmsFlag
    hmsFlag = True
then it will modify the global hmsFlag.
Similarly, your hundredsmsTasks function needs a
global hms
statement (in this case you'll get an error without it because you're trying to read the local before it was assigned).
Posted: Fri Oct 31, 2014 7:58 am
In fact a global declaration in hundredmsTasks() is optional, and an error won't be thrown in its absence. This is because hundredmsTasks() reads hms before it tries to write to it, and Python's scoping rules ensure that, having failed to look up the name in the function's scope it looks in the global scope*.
On the other hand hmsInt() only writes to hmsFlag so Python assumes that the intent is to instantiate a local variable. In this instance the global declaration is necessary to ensure Python looks for the variable in the global scope rather than creating a local variable with the same name as the global.
This isn't intended as Python pedantry: it's a bit of a "gotcha" in Python and it's worth having an understanding of these rules. Demonstration:
>>> rats = 1
>>> def rat():
...   if rats:
...     print("rats")
...   else:
...     print("No rats")
>>> rat()
rats
>>> rats = 0
>>> rat()
No rats
* Strictly it's slightly more involved: look up "Python scoping rules" for a full exposition.
Regards, Pete
Posted: Fri Oct 31, 2014 2:32 pm
by dhylands
pythoncoder wrote:In fact a global declaration in hundredmsTasks() is optional, and an error won't be thrown in its absence. This is because hundredmsTasks() reads hms before it tries to write to it, and Python's scoping rules ensure that, having failed to look up the name in the function's scope it looks in the global scope*.
ok - then I think there may be a bug in micropython? Because without the global statement in hundredmsTasks, I got the following error:
>>> import hsm
  File "hsm.py", line 31, in <module>
  File "hsm.py", line 14, in hundredmsTasks
NameError: local variable referenced before assignment
Posted: Fri Oct 31, 2014 5:10 pm
Oops! Micropython is behaving correctly and the global statement is required. In the example I gave, the function doesn't assign to the global, only reading its value, so no error is thrown. The global declaration is required because hundredmsTasks() modifies the global variable. I said Python scoping rules are tricky. I forgot just how tricky. Sorry about that.
Regards, Pete
Posted: Mon Nov 03, 2014 3:43 pm
by Gordon_Hardman
Thanks to both of you! I should have realized, as this is exactly how it works in Synapse Wireless' SNAP embedded Python too. Don't normally think about globals in Python for PCs, with multitasking or threads- just use FIFOs...
