[SOLVED] I2C reliability reading second byte issue
rpi_nerd
Post by rpi_nerd » Fri Sep 01, 2017 2:08 pm
Been learning how to use i2c under Micropython. I've figured most of it out, but I have a frustrating issue with reliably receiving the second temperature data byte from my temperature sensor. I've even lowered the i2c frequency down to 1KHz and I'm still not receiving the second data byte occasionally.
I did a very similar configuration a while back under the Arduino IDE, and everything was rock-solid.
My configuration:
Wemos D1 Mini
DS1631+ i2c temp sensor (https://datasheets.maximintegrated.com/ ... DS1731.pdf)
4.7k pull-ups and a .1uF cap near the sensor
i2c = I2C(scl=Pin(5), sda=Pin(4), freq=1000) # pins d1 for clk and D2 for sda
time.sleep(2)
i2c.writeto(76,b'\x51') #set advanced temp sense to startup
def read_advanced_temp():
	i2c.writeto(76,b'\xAA')
	temp = i2c.readfrom(76,2)
	print(temp)
	time.sleep(3)
a sample of the output:
b'\x1a\xd0'
b'\x1b\x80'
b'\x1c0'
b'\x1c\xb0'
b'\x1c\xa0'
Re: I2C reliability reading second byte issue
Post by deshipu » Fri Sep 01, 2017 4:14 pm
The example output you showed has 2 bytes in every reading. It's just that one of those bytes happens to be 0x30, which python renders as "0" when you print the string. Maybe that is throwing you off?
rpi_nerd
Post by rpi_nerd » Fri Sep 01, 2017 4:21 pm
Thanks for the explanation, I'm seeing it now, WebREPL is formatting those numbers as asii characters, got it.
