interface to handle callback from C code
I've understand about creating an interface in C to be called from python. What I need now is how if I wanted to set callback from python, and then call those callback is from C. or maybe create some kind like software interrupt from C. how can I achieve this?
Re: interface to handle callback from C code
The c_sample code mentioned in this thread: viewtopic.php?f=16&t=2861&p=19206#p19206 shows calling C code from python and having the C code call a callback written in python.
In particular, this line: https://github.com/dhylands/micropython ... c46acdfR24
dhylands wrote:The c_sample code mentioned in this thread: viewtopic.php?f=16&t=2861&p=19206#p19206 shows calling C code from python and having the C code call a callback written in python.
Ok, is it safe to do this?
mp_obj_t cb1_obj;
mp_obj_t cb2_obj;
STATIC mp_obj_t c_sample_set_callback1(mp_obj_t callback_obj) {
cb1_obj = callback_obj;
return mp_const_none;
STATIC MP_DEFINE_CONST_FUN_OBJ_1(c_sample_set_callback1_obj, c_sample_set_callback1);
STATIC mp_obj_t c_sample_set_callback2(mp_obj_t callback_obj) {
cb2_obj = callback_obj;
STATIC MP_DEFINE_CONST_FUN_OBJ_1(c_sample_set_callback2_obj, c_sample_set_callback2);
extern mp_obj_t cb1_obj;
extern mp_obj_t cb2_obj;
mp_call_function_0(cb1_obj);
mp_call_function_0(cb2_obj);
That looks reasonable. Note, that when calling code from within an ISR you should wrap the call in a try/except. In C code this would look something like this:
https://github.com/micropython/micropyt ... 1376-L1396
That also disables memory allocations (since ISRs aren't allowed to perform memory allocations).
The nlr_push returns 0 if the code runs with no exception and returns non-zero if an exception was raised.
dhylands wrote:That looks reasonable. Note, that when calling code from within an ISR you should wrap the call in a try/except. In C code this would look something like this:
I've try your sample code, but it fails to run the callback (no exception is raised but it just reset and back to repl), do you think below mp_obj_t should be initialized into callback object before called?
mp_obj_t cb1_obj;
mp_obj_t cb2_obj;
Last edited by ajie_dirgantara on Wed Sep 27, 2017 3:06 am, edited 1 time in total.
Yes. If you don't call set_callback and then try to call call_callback you'll get a crash. You should probably initialize them to the none object (mp_obj_t)&mp_const_none_obj; and then you can test if they're set before trying to call them.ajie_dirgantara wrote:dhylands wrote:I've try your sample code, but it fails to run the callback (no exception is raised but it just reset and back to repl), do you think below mp_obj_t should be initialized into callback object before called?
mp_obj_t cb1_obj; mp_obj_t cb2_obj;
