_thread limitation on stmhal ports
ajie_dirgantara
Post by ajie_dirgantara » Tue Oct 17, 2017 9:27 am
I am using stmhal port, and been using _thread module. Is the thread creation limited at 8 threads only?
because when I try to start 9th thread it raise MemoryError exception :
  File "main.py", line 221, in <module>
  File "main.py", line 219, in main
  File "main.py", line 204, in mainModeNormal
MemoryError: memory allocation failed, allocating 4096 bytes
Online
Re: _thread limitation on stmhal ports
Post by pythoncoder » Tue Oct 17, 2017 9:49 am
I think threading is fairly RAM intensive. If you can tolerate cooperative scheduling uasyncio is highly efficient: I have tested with hundreds of coroutines.
ajie_dirgantara
Post by ajie_dirgantara » Tue Oct 17, 2017 10:36 am
I'll stick with _thread module for now. But I'll take a look later. Thanks.
