Import custon module into script
christian.pinto
Post by christian.pinto » Fri Nov 14, 2014 1:41 pm
Hi all,
I am trying to define a few custom python modules to be used in my scripts. My custom module works pretty well, except for the fact that i can not import in into a script.
My idea was to do something like:
import my_module
While True:
  module_obj.func()
Bu then i get the following error: No module named 'my_module'.
While the custom module works if i do: my_module.module_obj.func().
To create the custom module I took the pyb module as a reference.
Is there something specific to do to allow the module to be imported into a script??
Thanks in advance,
Christian
Re: Import custon module into script
Post by dhylands » Fri Nov 14, 2014 10:20 pm
If you just do:
import my_module
then you'll need to prefix everything from my_module (so my_module.module_obj)
However, if you do:
from my_module import module_obj
then you can use module_obj without a prefix.
This is the same between python and micropython.
