Page 3 of 4
Re: Re-import module?
Posted: Thu Nov 27, 2014 5:50 am
TFT, as usual this pensioner is behind the curve ;) At least we now have a specific piece of Cpython functionality to discuss.
reimport imported Modules (del ?)
Posted: Sun Nov 30, 2014 7:28 pm
by polygontwist
How can I delete an imported module to import it again?
I found the command "del",it works(?) but it does not delete the imported module.
I write .py files and would like to import again without resetting the board.
(edit: v1.3.4-1-g3e42570 on 2014-10-22)
Posted: Sat Dec 05, 2015 12:25 pm
by pfalcon
sys.modules is now implemented, so it's possible to trigger re-importing of a module.
Posted: Fri Dec 11, 2015 11:38 am
by SpotlightKid
Very good!
Posted: Sun Dec 13, 2015 10:37 am
@pfalcon Very useful!
@polygontwist In case you didn't follow @pfalcon's post, Python caches imported modules in a dictionary called sys.modules. This caters for the case where a module gets imported more than once: if it's in the dictionary Python doesn't bother re-importing it. So, if you want to re-import module foo, with a new firmware build issue
import sys
del sys.modules['foo']
import foo
Posted: Sun Dec 13, 2015 8:14 pm
by Roberthh
Basically that works and is very useful. But if the first loaded module contains and registers an ISR, this one will be called, and any signaling using a global symbol will not work, since the first loaded ISR and the secondly loaded module will stare at different places At least that's what I observed when I tried to use the approach after pfalcon announced it. And obviously, the first loaded modules still sits in memory.
Posted: Sun Dec 13, 2015 8:33 pm
by SpotlightKid
Roberthh wrote:But if the first loaded module contains and registers an ISR, this one will be called, and any signaling using a global symbol will not work,
Thats one reason why using module globals to keep state is usually bad programming practice and executing code on import (e.g. registering an ISR) even more so. The same problems would exist with CPython. It also can't magically update any existing object instances from the re-imported module to use the new code.
Posted: Sun Dec 13, 2015 9:02 pm
by dhylands
So wouldn't loading the module the second time - reregister the ISR, thus replacing the old definition?
There is still a window where if the ISR occurs between deleting the old module and re-importing the new one where it will still point to the old routine, but as soon as the new ISR is registered, the old one should go away. There are some exceptions (like Exti) where if you were planning on using reimporting, then I would register an ISR of None, first, and then register the new ISR.
Posted: Mon Dec 14, 2015 5:57 am
by Roberthh
Actually in the example code I used the ISR was registered by a function in the loaded module, not at load time of the module, and the interrupt is caused by a one-shot timer. I may set up an example where the interrupt is triggered by an external pulse generator, where I can better control how many events occur. And thinking about SpotLightKid's comments, it could also be that it is the global which is not updated. I could try to look further. In any case, I would expect that loading a module would replace or re-use previous symbol definitions.
And, b.t.w., there was not specific reason to use that example code. It was just a short piece of code at hand that was loaded to the WiPy.
----- Update ----
Trying to simplify the test, it looks as if runs everything as expected on PyBoard. Here is the short test code:
import sys
from pyb import Timer, LED
fired = None
def reload(time=1):
    global fired
    print ("Enter the magic ANYKEY or 'q' to quit")
    tim = Timer(1)
    tim.init(freq = time)
    tim.callback(my_interrupt)
        fired = False
        ch = sys.stdin.read(1)
        print ("{!r} {} ".format(ch, fired), end="")
        if ch == "q":
            tim.deinit()
            print ("")
            break
def my_interrupt(timer):
    global fired
    fired = True
    LED(1).toggle()
I can delete the module from sys.modules, change the code (e.g. by choosing LED(2)), reimport it, and then the other led lights up, and the stae of 'fired' is changed too. A similar code on WiPy w/o LED behaves strange. I can load it once, it triggers the 'fired' flag. But if I quit and call the function again, the flag is never changed again, until I do a HARD reset. Thats with build 1.5.1-116. That seems to be the reason why I assumed that reloading did not work. Here's the Wipy code:
import sys
fired = None
def reload(time = 1000000):
    global fired
    tim = Timer(1)
    tim.init(mode = Timer.ONE_SHOT, width = 32)
        tim_ch = tim.channel(Timer.A | Timer.B, period = time)
        tim_ch.irq(handler = my_interrupt)
        fired = False
        if ch == "q":
            tim.deinit()
            print ("")
            break
    global fired
    fired = True
Posted: Thu Dec 17, 2015 10:02 am
For all its limitations reload can be very useful. I've put the following in boot.py (so that reload appears in Python's namespace).
def reload(mod):
    import sys
    z = __import__(mod)
    del z
    del sys.modules[mod]
    return __import__(mod)
It differs from the Python standard function in that the name of the module to be reloaded must be passed as a string:
PYB: sync filesystems
PYB: soft reboot
MicroPython v1.5.1-127-g67a5bfc on 2015-12-17; PYBv1.1 with STM32F405RG
>>> import cow
0
>>> reload('cow')
0
<module 'cow' from 'cow.py'>
Perhaps someone fancying a puzzle for the festive season can fix this?
