Re: Re-import module?
Posted: Thu Dec 17, 2015 8:43 pm
You can use __name__ on a module to get its name. It's not perfect. I see that CPython uses module.__spec__.name.
I created /flash/make_x.py: and use the following reload function in my /flash/boot.py: and this is the result:
Note that if some other module had imported x, it will still have a reference to the old module and not the reloaded one.
def incr():
with open('/flash/x.py', 'r') as f:
lines = f.readlines()
fields = lines[0].split()
old_x = int(fields[2])
new_x = old_x + 1
except OSError:
new_x = 0
with open('/flash/x.py', 'w') as f:
print('Updating x to {}'.format(new_x))
f.write('value = {}\n'.format(new_x))
f.write("print('value = {}'.format(value))\n")
def reload(mod):
import sys
mod_name = mod.__name__
del sys.modules[mod_name]
return __import__(mod_name)
MicroPython v1.5.1-117-g57dcfa3-dirty on 2015-12-13; PYBv1.0 with STM32F405RG
>>> import make_x
>>> make_x.incr()
Updating x to 0
>>> import x
value = 0
>>> x.value
0
>>> make_x.incr()
Updating x to 1
>>> x = reload(x)
value = 1
>>> x.value
1
>>> make_x.incr()
Updating x to 2
>>> x.value
1
>>> x = reload(x)
value = 2
>>> x.value
2
